Battery Dying a lot.
Old Mar 14, 2004 | 05:33 PM
mongoliandonuts's Avatar
Default Battery Dying a lot.
The battery dies a lot and it runs alright but it wont turn on i have to pop the clutch or jump it and whe ndriving the radio cuts in and out and the lights fade etc. the battery is new, and the alternator came new with the new engien i jsut swapped in so i don't think its that could it be something with the connection to the battery from the alternator or a ground or something any suggestion are welcome please!
Old Mar 14, 2004 | 05:41 PM
ekb18cCivic's Avatar
Default Re: Battery Dying a lot. (mongoliandonuts)
sounds like the alternator to me... even if you say it is new... it could also be a ground... did you look to see if you had any loose connections?
Old Mar 14, 2004 | 05:55 PM
clm's Avatar
clm
Default Re: Battery Dying a lot. (ekb18cCivic)
Make sure you have enough tension on the alternator belt.
Old Mar 14, 2004 | 06:20 PM
letmeseeyouskip's Avatar
i am pretty sure it is the alternator... you might have done something to the electrical problems
SpoonEk253
Jan 5, 2022 09:23 PM
raidacaipo
10
Jul 29, 2008 01:13 AM
obuhmyuh
May 28, 2008 03:27 PM
Fatty_1775
Oct 23, 2002 02:33 AM
