Can someone post photos of fuel injectors from a B18?
Old Mar 14, 2004 | 11:56 AM
opto_isolator's Avatar
Default Revised - can someone measure the tips of their pintle injectors?
I need to get some custom injectors for my setup. Someone said that the injectors from a B18 would fit - but would like to see some photos of any (if possible) before I drop some cash on them.....
Thanks!
Update, I've seen photos - now all I need are measurements - anyone??? I need the diameter of the pintle tip, plus how large the o-ring is.....
Modified by opto_isolator at 5:10 PM 3/15/2004
Old Mar 14, 2004 | 12:59 PM
onePOINTsix's Avatar
Default Re: Can someone post photos of fuel injectors from a B18? (opto_isolator)
all honda fuel injectors are basicly the same except the H22s which are 325cc i think, Pre 1991 are low impedence, 1992 on are High impedence, no point of running B18 injectors seeing that they are 235cc (i think) just like your your stockers
Old Mar 14, 2004 | 01:07 PM
Default Re: Can someone post photos of fuel injectors from a B18? (Sideout)
Thanks for the info - but I have an 01 civic, and the damn injectors are tiny (2" in length), plus they are not rebuildable (according to RC Engineering). I was going to go with Venom, but I need to know what will fit the injector bosses. The 01 civic uses injectors which have an o-ring at the tip, whereas some of the other styles out there don't appear to have an o-ring. I'm not sure how this will seal up, which is why I need to see some photos. The B18's which I am going to get (if they fit) will have a higher than stock flow rate (390cc's) for the power which I am planning to put down. There are 3 things I need to make sure before I buy them though:
1. What does the connector look like (there are a bazillion connectors out there)
2. What does the injector physically look like
3. Will it fit
I'm hoping that someone will graciously post photos if they have them so that I can tell at least 2 of the 3!
Thanks...
Old Mar 14, 2004 | 02:23 PM
oh sorry, didnt know your setup, bump for some needed info
Old Mar 14, 2004 | 02:28 PM
See first post - need info instead of photos
Old Mar 15, 2004 | 08:11 AM
Default Re: (opto_isolator)
ttt
MyF20b_Prelude
May 30, 2015 08:43 PM
DJaeMac
Honda Civic (2001 - 2005)
Aug 31, 2007 09:13 PM
88crxhfb16
Aug 18, 2005 09:40 AM
EVIL_AWD
Nov 20, 2003 04:58 PM
