GSR parts on b18a1
Old Mar 14, 2004 | 08:51 AM
King-Kong's Avatar
Default GSR parts on b18a1
Hey guys, i just bought a b18a1 and I am doing a total rebuild. I am not using a vtec head just all stock components. I was wondering if I could use a gsr water pump, oil pump and timing belt on my b18a1. Thanks alot ... chris
Old Mar 14, 2004 | 11:53 AM
ThirdGenLSR209's Avatar
Default Re: GSR parts on b18a1 (turbo_CRX)
Modified by ThirdGenLSR209 at 3:29 AM 3/15/2004
Old Mar 14, 2004 | 01:44 PM
Redline130's Avatar
Default Re: GSR parts on b18a1 (ThirdGenLSR209)
He is not building a LS/VTEC, just rebuilding the LS motor. I don't think it is necessary to use the GSR parts that you mentioned, you can if you want though. Just make sure you use OEM parts, can't beat the quality.
Old Mar 14, 2004 | 06:41 PM
King-Kong's Avatar
yeah i would be getting all my stuff through honda i just want to know if the gsr stuff would fit my block and what year water pump, oil pump and timing belt should i use on my 90-93 integra ls block(b18a1)
Old Mar 14, 2004 | 08:46 PM
Dan GSR's Avatar
Default Re: (turbo_CRX)
if you use gsr water pump, you MUST use gsr timing belt
those two, with a gsr oil pump, will go on your car just fine
good way to maintain the motor
Old Mar 14, 2004 | 08:48 PM
Dan GSR's Avatar
Default Re: (Dan GSR)
use the newer year gsr oil pump like a 2000
the older ones like the 94, are different, are belived to be not as good
Old Mar 15, 2004 | 12:33 PM
King-Kong's Avatar
thanks alot dan gsr, really helpful, I just came back from honda and picked up a 95 gsr oil pump, timing belt and water pump. Cant wait to get my 90 ls engine going.
770_dc2
Nov 17, 2010 04:17 PM
KdF
Mar 10, 2009 05:36 PM
I got a honda
Aug 1, 2005 10:42 AM
1hottEG6
Apr 13, 2002 04:33 PM
98 Ek LsVtec
Oct 25, 2001 05:53 PM
