ECU wont turn on and car doesnt start!
Old Mar 15, 2004 | 10:29 AM
turbocivic96's Avatar
Default ECU wont turn on and car doesnt start!
OK heres the deal. All of a sudden the car died at the light and wouldnt start again. I noticed that the Fuel Pressure guage read 0 at the rail. OK so i thought i blew the fuel pump. But then i noticed that the main relay wasnt doing its normal click over sound and was not telling the fuel pump to prime. SO now im thinking i blew the main relay. Well $70 later i find out the relay wasnt the problem. I manually sent the signal no the relay to turn on and it does. Now it sent the signal to the fuel pump and the pump primed. Can anyone tell me why the ECU is not sending the signal to the main relay to ground it out. The weirdest thing about this is that the CEL is on but stays on. There is no code at all. Even when i plug in a p2p or my coverted p28. Nothing happens. The CEL doenst even flash or think about going off. I checked all my fuses and nothing is blown. SO long story short my car doesnt start, the main relay isnt gettting a signal from the ecu and the CEL is nice and brite on my dashboard. ANy help would be much appreciated. You can call me with info if you like 973-668-8180
1996 Civic EX-T
Old Mar 15, 2004 | 10:39 AM
nevamind's Avatar
Default Re: ECU wont turn on and car doesnt start! (turbocivic96)
I have the same problem as you, main relay good, fuel pump good, but my problem is the car would start and die. CEL stay on when jumped the service connector. I'll let you know if I found anything have to do with this problem
Old Mar 15, 2004 | 12:34 PM
Default Re: ECU wont turn on and car doesnt start! (HIStateEG6)
Hey actually i jsut fixed it. I could not believe it but the map sensor had a punched wire that came off but i never would have known because it was far down the loom when i found it. I ended up tracing every single wire from the engine back to the ECU until i found the map sensor. Let me tell you how frustrating this is. I am a honda tech in NJ and the guys at the shop had no clue where to start nor was there a proper diagnosis to fix this acording to the Honda shop manuals. I just used a wire diagram and worked backwards and found it so if i were you i would check the map sensor and the Air Intake Temp sensor bcause they are linked together in the same loom for 96-00 civics. thanks
Old Mar 15, 2004 | 12:44 PM
nevamind's Avatar
My case is a little different from your. I'm installing a 96 LS (OBDII) into 92 Hatch (OBDI) For some reason my DX MAP sensor is remotely located on the firewall, and the LS MAP sensor is intergrated on the intake manifold. Now that I deal with two plugs for the MAP sensor, one is the stock Civic plug (not part of the harness) and the other is the LS plug (together with the harness). I can disregard the LS plug, but I must use the stock Civic plug or else I'll have a CEL. I was thinking of matting them together to see how it run. Good to know that your problem is fix.
Rick Overton
33
Aug 6, 2015 07:47 PM
hotinteggy
Oct 22, 2007 04:44 PM
civiclxb16a
33
Mar 7, 2005 08:29 PM
turbocivic96
Mar 15, 2004 12:35 PM
wronghand
14
Aug 10, 2002 11:30 AM
