GSR CLUSTER INTO EG HELP PLEASE HELP ASAP
Old Mar 14, 2004 | 05:41 AM
JDM*BUBBLE's Avatar
Default GSR CLUSTER INTO EG HELP PLEASE HELP ASAP
I juss did a integra dash swap into my eg and everything was workin fine but i kept throwing a cell for the speed sensor,
and to get to the point, for some reason i wired up the HOT wire to the VSS on the cluster i went for a test drive everything was good than the cel came on and the cluster juss lost power
Now my question is, Did i **** up the cluster?? i know it was stupid wiring up the HOT wire to the cluster but i dunno wat i was thinking, i was juss frustrated spendin 3 hours and it bein 6 am and all tryin to fix **** and i juss made it worse
So did i fry the cluster?? wat can i do to check?? Any help or suggestions would be greatly apreciated
Also since that happened my signals dont work, The Hazards flash but i cant signal left or right
Thanx for the help and info
Old Mar 14, 2004 | 06:19 AM
shermanyang's Avatar
Default Re: GSR CLUSTER INTO EG HELP PLEASE HELP ASAP (strictlyredline)
ouch...that would suck if you fried your electrical system. sorry i really can't help you figure out why your turns don't work but here's the wiring diagram that i used to wire in my GSR cluster into my EG.
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Old Mar 14, 2004 | 06:28 AM
JDM*BUBBLE's Avatar
Default Re: GSR CLUSTER INTO EG HELP PLEASE HELP ASAP (shermanyang)
Thanx for the info
The cluster is already all wired up and all
but it juss wont turn on
theres power goin to the cluster
i checked the clips with teh voltmeter
i guess i messed up my ****
lol next time ill keep my stock dash
Old Mar 29, 2004 | 03:51 PM
virginia_dude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">ouch...that would suck if you fried your electrical system. sorry i really can't help you figure out why your turns don't work but here's the wiring diagram that i used to wire in my GSR cluster into my EG.
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
That doesn't match the wiring of the GSR cluster I am holding 9&10 of the 16 pin connector trace to dash lighting. For starters.......
Old Mar 29, 2004 | 04:48 PM
stackz's Avatar
at the jetties fishin'
Community Builder
check your fuses...
sounds like you blew the main power fuse to the cluster either under dash or under hood...
deemy72
Feb 26, 2009 07:30 PM
NinetyTwoHB
14
Oct 31, 2005 09:45 PM
KenTegra
Feb 20, 2004 09:57 AM
