transmission rebuild question
Old Mar 13, 2004 | 03:18 PM
Malachi's Avatar
Default transmission rebuild question
i replaced 2nd and 3rd syncro's in my gsr tranny. i reassembled and installed. now i cant get the shifter into any gears. the only thing i can think of is the gear selecting arm inside the transmission must not be installed correctly. im not sure if there are any tricks or a certain way it should be done. i had the helms there but it didnt say anything specific to this part of reassembly. any ideas?
Old Mar 13, 2004 | 08:34 PM
doublejz's Avatar
Default Re: transmission rebuild question (Malachi)
might be your fork, if its not lined up right it will lock you outta your gears
Old Mar 14, 2004 | 12:08 AM
Syner-G-Racing LLC's Avatar
theres a locking pin, that you may have not reinstalled, or it could be the shifter fork. double check and make sure you put all of the shims in properly.
Old Mar 14, 2004 | 01:56 AM
simple4012's Avatar
New User
Default Re: transmission rebuild question (Syner-G-Racing)
trannys suck. they are very hard to learn. do yourself a favor. after the case goes back on. test it BEFORE its in the car lol....
just take it out and check everything overthen reassemble.....repeat as needed
d_EG COUPE
12
Jan 5, 2008 10:17 AM
tomato_man
10
Apr 15, 2007 06:56 PM
dohc_profile
19
Feb 15, 2007 07:43 PM
davidluko
Dec 17, 2006 10:51 AM
Leets
May 21, 2002 03:49 AM
