Can i use brake cleaner to clean out the IACV?
Old Mar 13, 2004 | 12:37 PM
sleepyhamsterlx's Avatar
Default Can i use brake cleaner to clean out the IACV?
the reason, Throttle body cleaner sux, the brake cleaner eats through grime better.
Old Mar 13, 2004 | 12:50 PM
743's Avatar
743
Default Re: Can i use brake cleaner to clean out the IACV? (sleepyhamsterlx)
I've used both carb cleaner and brakleen. Either will work.
Old Mar 13, 2004 | 12:53 PM
Default Re: Can i use brake cleaner to clean out the IACV? (-743-)
thannks
Old Mar 13, 2004 | 04:30 PM
Justin Jones's Avatar
What about when the brake cleaner gets into the engine? Anything to worry about?
I'm concerned! lol
Old Mar 13, 2004 | 04:37 PM
ekb18cCivic's Avatar
Default Re: Can i use brake cleaner to clean out the IACV? (the kid 86)
you should be fine with brake cleaner... it is very fast drying
Old Mar 13, 2004 | 05:41 PM
NonovUrbizniz's Avatar
Loved
Most dealers recomend using low levels of compressed air or water... no chemicals... but I've never used anything but carb cleaner or brake cleaner nor has ANY other mechanic I know of and non of them get f'd up...
I'm not even sure if honda recomends against using chemicals... I'll check my helms tonight...
Either way... use the carb/choke cleaner... it will work fine and you have nothing to worry about either running in the engine... IF...
A. You don't hose it down...
B. You leave it apart for adequet time for all of the spray to evaporate off...
C. You spray the IACV while it's off the intake.
It's not often but more than possible to wet down the plugs with carb cleaner... preventing the car from starting for a while....
It happened to one of the kids working on his car after work at my buddies station...
Old Mar 13, 2004 | 09:35 PM
BatuKing's Avatar
Default Re: Can i use brake cleaner to clean out the IACV? (NonovUrbizniz)
well FYI guys.. you dont use CARB cleaner on a Throttle body car.. because TB have a coating on them that the harsher CARB cleaner will remove.. (yes I know I will get flamed but Oh well )
best one to use is parts cleaner or brake cleaner.. or if you want to spend money get Throttle body cleaner.
Old Mar 15, 2004 | 07:02 PM
Loved
Default Re: Can i use brake cleaner to clean out the IACV? (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">well FYI guys.. you dont use CARB cleaner on a Throttle body car.. because TB have a coating on them that the harsher CARB cleaner will remove.. (yes I know I will get flamed but Oh well )
best one to use is parts cleaner or brake cleaner.. or if you want to spend money get Throttle body cleaner.</TD></TR></TABLE>
What's the coating and what purpose does it serve?
Old Mar 15, 2004 | 07:08 PM
JSJ EG6's Avatar
i used carb/choke cleaner on my iacv and idles better now.
Old Mar 15, 2004 | 07:15 PM
Caveman74's Avatar
Then why the hell do they sell it? I seafoamed my car with the throttle cleaner and manifold cleaner and it runs sooo much better. and i'm getting killer gas mileage know too
johnlvs2run
Oct 27, 2014 12:57 PM
mitchh29
10
Mar 19, 2013 04:21 PM
tpot90
Aug 17, 2008 10:11 PM
crazyguy
Sep 4, 2007 03:52 AM
dcfour
May 9, 2005 10:38 AM
