fuel problems...
Old Mar 13, 2004 | 10:58 AM
Sobe_Death's Avatar
Default fuel problems...
ok, so im trying to start up the ZC, got my distributor problems taken care of, now the #2 and 3 cylinders seem to be getting an outrageous amount of fuel when cranking. as in standing puddle of gasoline on top of the piston when i look in the plug hole. anyone know what could be doing this? i think that i have a faulty injector, or resistor box, or maybe i have the wrong injectors on there. i do also have a set of prelude injectors that may have gotten mixed up with the ZC injectors, but im not sure how to tell the difference without finding a shop to flow test them.
Parker, who wishes he paid more attention during disassembly
Old Mar 13, 2004 | 11:29 AM
89civicdx's Avatar
Default Re: fuel problems... (Sobe_Death)
any codes showing up?
Old Mar 13, 2004 | 11:42 AM
Sobe_Death's Avatar
negative on any relavent codes, getting a code 20, but not too worried at this time
Old Mar 13, 2004 | 12:09 PM
WhiteEG6's Avatar
How old are the injectors? I had the same problem when building my motor. I had 2 defaulty injectors.(stuck open) IM not sure how that could have occured but you might want to check that.
Old Mar 13, 2004 | 12:11 PM
Sobe_Death's Avatar
zc is stamped 89 on the head, im guessing the injectors are as old
Old Mar 13, 2004 | 02:02 PM
Sobe_Death's Avatar
k, now im back to square 1, before i replaced the dizzy yesterday, i was getting a code 15 for a missing or defective ignition output signal. replaced the dizzy with one from a working motor, code goes away. later today, the code 15 comes back, wtf mate? this , plus the injector thing, plus a headgasket leak now, im quite irritated
ohgodbadname
May 26, 2012 02:38 PM
jining
Oct 8, 2009 01:53 PM
Morbspeed
Jan 13, 2004 05:51 PM
sloweh3
Oct 21, 2003 08:30 PM
