removing layers from stock head gasket (searched)
Old Mar 13, 2004 | 08:37 AM
jazz1320's Avatar
Default removing layers from stock head gasket (searched)
mods please delete
Modified by jazz1320 at 9:50 AM 3/30/2005
Old Mar 13, 2004 | 09:17 AM
Kataku2K3's Avatar
Default Re: removing layers from stock head gasket (jazz1320)
It's possible and has worked but I do not recommend and never do it myself. At standard bore you can expect about a ~0.25:1 increase for every 0.010" or 1 layer so with 2 layers gone you'll be ~0.50:1 up which isn't all that big of an increase. The biggest issue is sealing, where a stock headgasket has a little "play" to seal, you won't get this with a 1 layer. I personally wouldn't mess with the headgasket, if you wanna bump up your compression do so with pistons. Just my $0.02
Old Mar 13, 2004 | 10:45 AM
jazz1320's Avatar
Default Re: removing layers from stock head gasket (Kataku2K3)
so sealing with be the only issue!!.. i have copper spray too
Old Mar 13, 2004 | 10:57 AM
Kataku2K3's Avatar
Yea basically, copper spray is cool and will help too.
silentdaredevil2
Nov 24, 2005 12:29 PM
Evs-One
Mar 3, 2003 01:09 AM
schwett
Apr 18, 2002 04:19 PM
paulzy
Nov 8, 2001 12:21 AM
