Vtec activation light by accident
Old Mar 12, 2004 | 11:47 PM
Option's Avatar
Default Vtec activation light by accident
Ok guys this is a wiered problem. I did a SiR II swap into my 98 DX about two months back everything works fine and dandy (except for brakes), and i am ordering a b20 block soon and everything. So yesterday i am rollin around and i hit vtec for a breif second, and i notice my ebrake light flickers for a second so im like whatever, i didnt really care. And then later that evening i hit vtec again but for longer this time, and the ebrake light pops on and stays on and as soon as i drop out of VTEC it turned off, so them im like WTF is going on. So i start messing around hitting VTEC in all of my gears and stuff and i notice, that everytime i hit vtec that damn light comes on. What i wanna know is WHY??, it just started doing this yesterday, and it wont stop. Any suggestions or OPINIONS????
Its the craziest thing ever i have no idea why it would do that.
Old Mar 13, 2004 | 12:13 AM
S9i1R's Avatar
Default Re: Vtec activation light by accident (Option)
that's some wierd **** has anybody else owned it? if so maybe they did something.
search I've never herd that happenin before
Old Mar 13, 2004 | 12:57 AM
pornstarSR's Avatar
Default Re: Vtec activation light by accident (S9i1R)
check brake fluid...maybe a instance of one thing leading to another...
maybe when you get on it and hit vtec it moves the fluid enough to cause the brake fluid resivour sensor to trip off giving the light
Old Mar 13, 2004 | 07:36 AM
PHiZ's Avatar
Default Re: Vtec activation light by accident (pornstarSR)
Or vacuum maybe, the check valve to the brake booster?
-PHiZ
Old Mar 13, 2004 | 07:43 AM
mmuller's Avatar
Mad Scientist
Default Re: Vtec activation light by accident (PHiZ)
parkin brake switch?
maybe when you hit vtec start pulling all those maaadd G's the switch moves....lol
Old Mar 13, 2004 | 06:19 PM
Option's Avatar
Default Re: Vtec activation light by accident (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">parkin brake switch?
maybe when you hit vtec start pulling all those maaadd G's the switch moves....lol</TD></TR></TABLE>
lol yeah that must be it
But im changing my rotars, and pads on wednesday, and changin the break fluid to, so ill jsut live with it till then, and if it the problem isnt fixed when i do that, then ill be back here asking for other options.
Old Mar 23, 2004 | 11:00 PM
ceLtic's Avatar
N/A wh0re!
LOW BRAKE FLUID! DUH! when your vtec kicks in it causes it to slush around and the sensor(pad looking thing hanging from the cap) goes up and down as the fluid is getting slushed around. add more fluid and you're all set.
Old Mar 24, 2004 | 06:11 AM
JSMC's Avatar
Default Re: Vtec activation light by accident (chrism)
their's a vtec light with the SIR cluster, no?? if it's not a mecanical problem, I think it may be an electrical one, maybe the vtec light out from the ECU come into your brake light, or those two light have a short-cut.
Old Mar 24, 2004 | 08:07 AM
sledgehammer's Avatar
Default Re: Vtec activation light by accident (JSMC)
Theres probably just someone hiding out in your backseat, pulling your ebrake whenever you're in vtec...
Old Mar 24, 2004 | 08:46 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Vtec activation light by accident (sledgehammer)
i had one of those little bastards in my back seat once , but i caught that little f**ker
Old Apr 28, 2004 | 08:50 AM
jbs's Avatar
jbs
Someone may have T the wire from your ebrake to the Vtec in the ecu to give them a Vtec light. Fluid in the reservior doesn't have to do with your ebrake light. All that activates it is a switch by your ebrake to close the circuit.
Old Apr 28, 2004 | 03:39 PM
STREETWERKZ's Avatar
Default Re: Vtec activation light by accident (jbs)
its low fluid.
jdmwannabe3
25
Apr 14, 2006 08:57 PM
CRX_Control
10
Feb 8, 2005 07:29 PM
Pineapple Devil
Oct 16, 2002 03:41 PM
Mr. Softee
Mar 13, 2002 09:24 AM
