Transmission problem...1998 SH.
Old Mar 12, 2004 | 06:08 PM
AgentUT's Avatar
Default Transmission problem...1998 SH.
I own a 1998 SH which has around 63k miles on it. I've had it since about July, and the transmission has been quite rough ever since I got it, but it was nothing unbearable..just an inconvienance.
But earlier tonight, I was trying to pull out of my driveway and it refused to get into Reverse. I tried a few times, and gave up. I let myself roll down in neutral and drove around for a bit warming the car up. I then stopped and tried again. And it didnt budge again. I have constant 5th gear grinds, and now this!
Looks like i'm going to have to have someone take a look at it. Anyone have any idea what may be wrong? And where I should take it to?
Old Mar 12, 2004 | 06:32 PM
Don Jefe's Avatar
Default Re: Transmission problem...1998 SH. (AgentUT)
Well, on my 97 SH with equal mileage, most of the time in the mornings or when i havent driven it in a while, i have to double clutch it in order for it to get into reverse. That meaning that i try to put it into reverse and it wont go in, i put it back in neutral, let out the clutch, push the clutch back in and then i can go into reverse no problem. Now i'm not sure if you've tried this or not, but it always works for me.
As for your 5th gear grinds, when was the last time you changed your tranny fluid?
Hope this helps.
Old Mar 13, 2004 | 12:40 PM
AgentUT's Avatar
Default Re: Transmission problem...1998 SH. (Hank the retard)
Well I tried today, and it went in, but sometimes it's difficult to take it out of reverse..
Sigh..
Old Mar 13, 2004 | 12:53 PM
AgentUT's Avatar
Does anyone know how many quarts of transmission fluid you need to pour in after a full drain? (manual)
Old Mar 13, 2004 | 01:08 PM
Bigjussin's Avatar
2 quarts on a base tranny....im assuming a sh shouldnt be much different
Old Mar 13, 2004 | 05:23 PM
DIE DIE's Avatar
hmmmm i just noticed today that my car wants to give a little scratch when i throw it into 5th quickly. You guys think that it just needs tranny fluid??
Old Mar 14, 2004 | 08:41 AM
tkm121988's Avatar
Default Re: (seecretninja)
Most of the time it's gas compilations on the under-motor clutch. It happens alot of the car is in a cold space for long period of times, and if you haven't drove it in awhile. But your best bet is probably taking it to a car fixing place, they can usually pinpoint it rather quickly.
Old Jun 9, 2005 | 10:51 AM
kriptik's Avatar
Default Re: (DIE DIE)
hey man, wut fixed ur problem on ur car with fifth gear. cuz i have the exact same **** happening too. thanx
Old Jun 9, 2005 | 11:02 AM
mafia's Avatar
Well happns to me too sometimes, what i do is put it into 5th, then take it pout and put it ito R then it usaly gose in... if not just put it in and out of dif gears
Old Jun 9, 2005 | 11:04 AM
Wiseguy619's Avatar
Possible bent shift fork for reverse. I had to get a new tranny for my SH.
teg969
Jul 21, 2008 01:07 PM
jairobeatz
Oct 27, 2006 12:25 AM
vietdragontekx
Aug 27, 2005 06:21 PM
Miz101
May 15, 2005 06:11 AM
skywlkr235
Aug 4, 2002 10:48 AM
