oil pressure sender was leaking then part of block broke!
the top part of the threading broke off when takign the oil pressure sender out to put guage, this was a while back, hehe my simplest solution was to keep pouring jb weld over it to seal it, worked for a good 5 months after motor was running, then theheat started making the jb pry away from the block, i was thinking rent a welder and just weld the hole completely shut, i have a oil filter sandwich so i will still get the oil pressure sender to work, while doing this i also got a hondata intake manifold gasket, what do u guys think? think i can weld it good with the intake manifold off? i dotn wanna pull the motor if not needed please help!
Mike D16Z6
Jun 14, 2010 02:45 PM
