distributor problems?! please help!!
Old Mar 11, 2004 | 10:06 PM
TegBen's Avatar
Default distributor problems?! please help!!
hi, i have this crazy thing with my car . . . .
92 Civic Dx HB with ZC swap . . . . anyways . . . the tach will sometimes . . . jump around all crazy and the motor feels as though its losing power when it does this . . . . could it be the distributor? if not what else . . . . wires, plugs, etc is ok . . .
also will a distributor off a b18 non vtec work?? assuming that is the problem of course . . .
Old Mar 11, 2004 | 10:11 PM
hondasleeper's Avatar
Default Re: distributor problems?! please help!! (HHB 2185)
Sounds like you have a short somewhere in your distributer. Do you have a MSD ignition and/or a blaster coil bye chance? If you do the wires in from the coil going into the distributer are getting frayed bye the rotor.
Whatever it is something is causing a short and it will cause you tach to jump around.
I don't think a B18 non vtec distributer will help, but then again I could be wrong.
Old Mar 13, 2004 | 11:50 PM
TegBen's Avatar
Default Re: distributor problems?! please help!! (hondasleeper)
well, i purchased a new distributor today and changed them out and there was no change . . . . the tach still jumps around . . . . . . . . i put in new plugs and wires and checked all my wires . . . . it even does it while im idle'ing now . . . . however when the idle changes, sometimes the tach will stop jumping around . . . . its crazy and its costing me money just to figure out what this is . . . .so if anyone has any other ideas or has experienced this before . . . please feel free to post any comments/suggestions that might be helpful . . . thank you
Old Mar 13, 2004 | 11:52 PM
MrIllegalX's Avatar
dude seriously...punctuation please.
Old Mar 14, 2004 | 12:01 AM
TegBen's Avatar
Default Re: (MrIllegalX)
dude seriously . . . . focus on the point of the thread, not on being an english major
oh yeah, . . . . . . .
Old Mar 14, 2004 | 12:25 AM
FrostySol's Avatar
if it does it while at idle and while driving I'd check your IACV. Are you throwing a CEL by chance?
Old Mar 14, 2004 | 10:05 AM
TegBen's Avatar
I'm not quite sure about a CEL but i do know, that since ive done the swap, ive been throwing a 19 and a 27 i believe. A TPS code and something else, electric lode or something . . I havent had the chance to check these out. Oh by the way, in my car, i changed the automatic out to a standard when i put in the zc. Do I have to switch the green and yellow wires going into the TPS plug? because thats the only thing i can think of that would be throwing that code. But as far as in the CEL or whatever , im not sure . . . . keep sending the posts . . . thanks
Old Mar 14, 2004 | 07:19 PM
TegBen's Avatar
cmon guys more posts, . . . . @ least list me some things to check . . . . im going tommorow to the mechanic, thanks
Old Mar 14, 2004 | 09:37 PM
TegBen's Avatar
anything? no?
Old Mar 26, 2004 | 01:54 PM
trev4's Avatar
Default Re: (HHB 2185)
So what happend? It sounds like my car is having the same problem, it just started today. My car stalled on me 3 times anywhere from idle to 2g rpm.
Old Mar 26, 2004 | 02:15 PM
leftbehind33's Avatar
Default Re: (trev4)
did you check the primary coil?? test the resistance and compare to spec.
Old Mar 26, 2004 | 02:21 PM
Default Re: (trev4)
what about at higher rpm, is it fine??
Old Mar 26, 2004 | 02:23 PM
Default Re: (leftbehind33)
did the shop do an exhaust gas analysis by any chance??
Old Mar 26, 2004 | 04:34 PM
trev4's Avatar
nah, none of that stuff, a little damn ground wire connecting to the transmission was loose. That's it!
1badcrx
May 9, 2009 12:58 AM
DOHCarp
Jun 13, 2007 09:28 AM
tigueremalo
Jan 28, 2007 11:24 AM
99sibluehatchwitb16
11
Jan 25, 2006 06:49 PM
FitCRX
Feb 2, 2003 11:38 AM
