Injector size will too big hurt?
Old Oct 18, 2001 | 11:01 AM
Spade's Avatar
Default Injector size will too big hurt?
I can get 550 cc injectors and they cost the same as 270 cc. Is it going to hurt or would the injectors only put out what is needed?
AND LAY OFF OF THE STUPID *** TITLE I DIDN"T READ INTO IT UNTIL AFTER I SENT THE POST.
[Modified by Spade, 8:01 PM 10/18/2001]
Old Oct 18, 2001 | 11:10 AM
sackdz's Avatar
Default Re: Injector size will too big hurt? (Spade)
I think that was a bad idea, nm.
[Modified by sackdz, 3:16 PM 10/18/2001]
Old Oct 18, 2001 | 11:13 AM
4WDrift's Avatar
Yep, can hurt (low rpm performance), too big can't be cycled on/off fast enough at idle without allowing TOO much gas injection. I'd think double would be too big.
Gary
Old Oct 18, 2001 | 11:14 AM
Spade's Avatar
Default Re: Injector size will too big hurt? (sackdz)
it's kewl man but, my question was would the injectors cut down there feed of fuel when the O2 says that it is running rich? I understand that too much fuel is bad but, why would the fuel management system over feed the fuel or can you not turn down the 550's? Or 310's or whatever!!!
Old Oct 18, 2001 | 11:47 AM
4WDrift's Avatar
The pipe is too big. Injectors cycle on/off at varying speeds like a camera shutter, more fuel means on is open longer. Bigger injectors are like a wider aperture, more fuel flows through. At idle, a bigger injector can only cycle so fast on/off and the large opening may still let too much gas through.
Old Oct 18, 2001 | 11:59 AM
Spade's Avatar
Default Re: Injector size will too big hurt? (4WDrift)
Okay so I would only want 310's on a somewhat stock B18C!?!
Old Oct 19, 2001 | 12:19 AM
Rain_man's Avatar
New User
You should decide on what you want to do to the car and then go with the size.
Old Oct 19, 2001 | 06:04 AM
VTC_CiViC's Avatar
Well FYI, you could use as large as a 450cc injectors with the aide of an AFC to trim them down appropriatley. Anything larger and it overwhelms the ECU and AFC altogether.
Old Oct 19, 2001 | 06:23 AM
Spade's Avatar
Default Re: Injector size will too big hurt? (VTC_CiViC)
Thanks VTC, I was wondering cause I do plan to swap the engine and I don't want to buy some injectors and then later on down the road have to buy bigger ones.
[Modified by Spade, 3:23 PM 10/19/2001]
Old Oct 19, 2001 | 06:35 AM
WAFFLES's Avatar
I'm dropping in my ls/vtec this month.
b18a bottom
b16a1 head
.25over ITRslugs
chipped p28 ecu with Mugen program and 8K rev limiter
What would be an appropriate injector size. I was thinking RC310's or 270's.
I will be dragging and auto-xing occasionally, but mainly daily driver.
Thanks in advance for your input.
Old Oct 19, 2001 | 07:04 AM
VTEC4GS's Avatar
Default Re: Injector size will too big hurt? (WAFFLES)
stock injectors will work fine for oyu, 234cc is stock sizing. Going 550cc is more than double the size ... and is a bad idea because:
1- ecu cant control that big
2- lots of plug fouling
3- way too much fuel because mugen program also increases inj duty more than stock
Greg
uvamosk
Sep 11, 2011 06:05 AM
lskid98
Mar 4, 2008 06:50 PM
B6teen
Jan 8, 2008 07:46 PM
AllMotorGSR94
Mar 10, 2004 02:35 PM
GOLDBERG
Oct 20, 2002 06:51 AM
