RSX/Civic hybrid
Old Oct 18, 2001 | 10:48 AM
6SPD_EK's Avatar
Default RSX/Civic hybrid
is anyone currently swapping a RSX engine into a new civic - will it bolt right in? what about suspension (from a DC5 R) just curious?
Old Oct 18, 2001 | 08:13 PM
SandSanta's Avatar
New User
Default Re: RSX/Civic hybrid (2000-4DRGSR)
The new Si is sporting an RSX engine. Shouldn't be too difficult; like swaping 'teg into the civic.
Old Oct 19, 2001 | 12:04 AM
Civic Hatch Boy's Avatar
New User
Default Re: RSX/Civic hybrid (CoffeCan)
the new si does not have the rsx engine.. they both have 2.0L engines, yes, but they are not the same. it's like saying the d16 is the same as the b16
also, rsx's engine rotates opposite direction from the civic now. dunno wut acura had in mind
[Modified by Civic Hatch Boy, 9:04 AM 10/19/2001]
Old Oct 19, 2001 | 08:51 AM
rsx2002's Avatar
New User
I think so. The new civic engine rotates the other way also doesn't it?
Old Oct 19, 2001 | 10:48 AM
6SPD_EK's Avatar
Default Re: RSX/Civic hybrid (Civic Hatch Boy)
oh well - it was a nice idea/thought
Old Oct 19, 2001 | 12:51 PM
00R101's Avatar
Don't listen to everything you hear on the list. It's probably an easy swap. Both engines rotate the same way (2001+Civic and RSX that is).
Old Oct 19, 2001 | 08:58 PM
iNteGraz92's Avatar
Default Re: RSX/Civic hybrid (00R101)
only the rsx and new si's engines rotate the same way. the other 01 civics engines rotate the "normal" honda way
Old Oct 20, 2001 | 10:06 AM
SandSanta's Avatar
New User
Default Re: RSX/Civic hybrid (iNteGraz92)
Though I would have to say the new Si is pretty ugly.
Old Oct 23, 2001 | 11:33 PM
ITR 2K's Avatar
I'm sure someone will find someway to do it. I'm sure we will be hearing about it in the not to distant future.
Old Oct 24, 2001 | 11:12 AM
MK Ultra's Avatar
Default Re: RSX/Civic hybrid (ITR 2K)
I wonder what the chances are of an S2000 motor bolting up to an RSX-S tranny...
Old Oct 30, 2001 | 08:55 AM
Gearheaded's Avatar
That is what I'm saying. I thought about the rsx engine swap, but after reading the specs and checking out my buddy RSX, you would have a hell of a time, and most likely spend way too much money. So what do you do??? You patiently wait for something, like I am doing... In due time however I make long tedious plans for the 2001 civic @ 400hp+ ( I know I'm dreaming, but like McDonald's ... It could happen)
Old Oct 31, 2001 | 04:40 AM
Trey's Avatar
25 Year Member
Default Re: RSX/Civic hybrid (civicman01')
You guys are thinking TOO hard!!
It doesn't matter which way the engine rotates. It's the way the engine is mounted in the engine bay. The 2001 Civics and the RSXs share the same mount points. Now since the new Si will have the RSX engine, that will be the mounts to use in the base Civics. Again, RSX motor, 02 Si mounts and brackets, 2001+ Civic chassis.
Old Oct 31, 2001 | 05:28 AM
6SPD_EK's Avatar
Default Re: RSX/Civic hybrid (Trey)
- thanks Trey - Time for me to get a used 2001 civic coupe
Old Nov 1, 2001 | 02:19 AM
Civicboy's Avatar
Oh my dear god yes that would be so sweet. I really don't like the look of the new hatch. I would much rather get a coupe and put a Type S engine in there and blow the doors off that new Si.
Old Nov 1, 2001 | 11:05 AM
NewYorkTypeR's Avatar
New User
Default Re: RSX/Civic hybrid (Civicboy)
Probably already happened b/c a type S came up missin around my way a while back. Probably a guinea(sp) pig for a nice hybrid.
Old Nov 2, 2001 | 10:47 AM
SandSanta's Avatar
New User
Default Re: RSX/Civic hybrid (NewYorkTypeR)
Ya I was thinking of just getting a Civic Coupe DX, junking the SOHC engine, and putting the -S engine in it's place. Would look nice with a body kit.
B_Swapped93
Honda Civic (2006 - 2015)
Jan 15, 2019 07:05 AM
HondaGSX
11
Apr 3, 2007 10:47 AM
fastludeh22
May 29, 2002 08:46 AM
MugenVtek4
Dec 2, 2001 05:21 PM
sykoward
Oct 7, 2001 09:03 PM
