Will a P06 ecu run my d15b vtec engine or a d16z6?
Old Mar 11, 2004 | 06:43 PM
Slammd Sol's Avatar
Default Will a P06 ecu run my d15b vtec engine or a d16z6?
I have a jdm d15b vtec engine using a p28 ecu, but i want to take it out and chip it for uberdata. While its out, would i be able to throw in an old P06 d15b7 DX ECU so that my car is still useable? I know it wont have vtec engagement but will it run without CELs?
Old Mar 12, 2004 | 05:53 AM
Slammd Sol's Avatar
ttt
Old Mar 12, 2004 | 06:10 AM
quicksol95's Avatar
Default Re: (Slammd Sol)
it should work fine with out the check engine light
b/c the p06 does not look for the vtec signals
Old Mar 12, 2004 | 08:48 AM
zer0.'s Avatar
Default Re: Will a P06 ecu run my d15b vtec engine or a d16z6? (Slammd Sol)
P06+VAFC will work.
Old Mar 12, 2004 | 02:14 PM
BauleyCivic's Avatar
Risky Business
Default Re: Will a P06 ecu run my d15b vtec engine or a d16z6? (zer0_2_6ixty)
It will run 100%. It wont be looking for VTEC however, so you will be running with the low-rpm lobe all the way up to the 6800 rev limit. If you aren't going to be racing in the period that you have it, it will run perfectly fine.
Old Mar 24, 2004 | 07:45 PM
darrinbrewer's Avatar
Default Re: Will a P06 ecu run my d15b vtec engine or a d16z6? (BauleyCivic)
i used a lx civic ecu to run my gsr one time...no problems..
djslim23
13
May 18, 2010 06:27 PM
jztoy
Jul 4, 2009 09:02 PM
awdriver
Apr 11, 2008 12:07 PM
ef9i@asia.com
Jun 25, 2006 06:33 PM
DevLishPlaya
Aug 4, 2003 10:53 PM
