JDM ITR axles question
Old Mar 11, 2004 | 06:06 PM
Project99EK's Avatar
Default JDM ITR axles question
my question is i have a 99 civic dx hatch and im putting a 96 spec itr in my car well all i need left is the axles ...i was told that i would have a problem putting 98 jdm itrs in my hub cause they are way thicker...is that true? i was also told the 97 usdm ones would fit...is that true as well...thanks again.
Old Mar 11, 2004 | 06:23 PM
mmuller's Avatar
Mad Scientist
Default Re: JDM ITR axles question (Project99EK)
yeah, jdm axles wont fit your stock hub, cant remember how much bigger they are, but they are bigger.
any b-series usdm will fit
Old Mar 11, 2004 | 09:43 PM
Default Re: JDM ITR axles question (mmuller)
ok what if i use a jdm intermediate shaft with usdm axles...will that be ok?
thanks by the way
Old Mar 11, 2004 | 09:50 PM
92b16vx's Avatar
The JDM five lug axles has a larger outer joint. You can use any 94+ Integra axle, 99-00 Si, or Del Sol vtec from 93-97.
And yes you can use any of the other axles on the JDM halfshaft, only the outer joint is bigger.
Old Mar 11, 2004 | 10:57 PM
Kataku2K3's Avatar
Default Re: (92b16vx)
Just for reference it's a 36mm spline/hub. We stopped doing JDM 5 lug swaps after Lane's FI motor because it's a pain in the *** when you break those axles as they're not as easy to attain or make.
Old Mar 12, 2004 | 08:32 AM
Default Re: (Kataku2K3)
thanks for your help guys...ok if it were u if your options were a 94+ gsr axles with 5000 miles or itr axles with 17,000 which would u pick? aslo already had a intermediate shaft from a 96 jdm itr but it has random miles all u know is under 40k would u just use that or buy the 97 usdm one with the axles?
Modified by Project99EK at 6:23 PM 3/12/2004
Old Mar 13, 2004 | 08:15 AM
Default Re: (Project99EK)
upppp
Old Mar 13, 2004 | 09:04 AM
Kataku2K3's Avatar
You're not really going to have any advantage either way so it's up to you, mileage isn't a huge factor either unless they've already been put under a lot of stress (i.e. lots of launching, etc.). I personally would just use the GSR and the stock halfshaft as they rarely wear out. You aren't converting to 5 lug with the 36mm hub, correct?
Hella Clean
Apr 24, 2004 02:35 PM
jdmjohn02
Jan 10, 2004 06:36 PM
oem
Jan 27, 2003 08:54 PM
Ehron
Nov 26, 2002 05:04 PM
Kid1320
Nov 24, 2002 04:34 PM
