Easiest way to check valve spring retainer "wear"?
Old Mar 11, 2004 | 09:39 AM
RTW DC2R's Avatar
Default Easiest way to check valve spring retainer "wear"?
My Crower Ti valve spring RETAINERS have about 15K on them now, and I drive the car pretty hard, so Im starting to worry about them getting worn. Is there a way to check them for wear without taking them out? About how long can I expect Ti retainers to last? If I have to take them out to check them, do I need to remove the cams? It looks like I can access them without removing the cams but Im not sure. Muchas GrassyAss.
edit:
Old Mar 11, 2004 | 09:45 AM
ZygSpeed's Avatar
Default Re: Easiest way to check valve spring retainer "wear"? (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">My Crower Ti valve springs ... </TD></TR></TABLE>
Hehe Damn! When't they come out with those?
But more to the point, I'd think you could get a fairly decent look at the retainers by just pulling the valve cover and carefully checking out the assembly (inspection mirror and flashlight might be needed).
No need to remove cams to even replace retainers (compressed air in the cylinder and a valve spring tool), though removing them for inspection is probably the only way to really gauge/measure their wear.
Old Mar 11, 2004 | 09:48 AM
RTW DC2R's Avatar
good idea with the mirror, it was hard to get a good angle to see the thickness so Ill give the mirror a try before trying to remove anything.
Old Mar 11, 2004 | 11:26 AM
MattD@Stoptech's Avatar
Default Re: (RTW DC2)
good idea with the mirror, it was hard to get a good angle to see the thickness so Ill give the mirror a try before trying to remove anything. </TD></TR></TABLE>
With that milage/age it might be a good idea to replace them anyway...treat them as a wear item...
Old Mar 11, 2004 | 12:16 PM
RTW DC2R's Avatar
would there be any drawbacks of putting my stock retainers back on? I know the Ti are stronger but wear down, and stock steel retainers can crack so Im not sure which would be best.
Old Mar 11, 2004 | 12:34 PM
B18CXr's Avatar
put the stockers back in mang
Old Mar 11, 2004 | 12:37 PM
RTW DC2R's Avatar
I think I just may do that.
anyone got a valvespring tool I can borrow
Old Mar 11, 2004 | 07:48 PM
sgT's Avatar
sgT
you should be able to tell by just looking at them.
Old Mar 11, 2004 | 08:05 PM
TypeR 599's Avatar
Default Re: (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to tell by just looking at them.
What would we be looking for? How thin is the retainer?
Old Mar 11, 2004 | 08:21 PM
RTW DC2R's Avatar
Thanks Steve, I know you have to LOOK at them. The problem lies in that they are DOWN inside the head and its hard to get a profile view of them to see how much they are worn, and be able to know if its time to change them or not.
ITR#132's Avatar
The last set of Crowers that I seen were really thin (New), and I suppose if those wore any youll alredy be in trouble.
import_king20
Mar 18, 2006 05:08 AM
delsolb16
14
Nov 9, 2005 04:02 PM
anthonylee29
Apr 19, 2005 11:01 AM
00b18b
Nov 21, 2003 11:08 AM
builthatch
Jun 19, 2002 08:00 AM
