valve stem seals?
Old Nov 8, 2003 | 06:37 PM
00b18b's Avatar
Default valve stem seals?
how do u remove and replace valve stem seals on a b18b head. is it diffcult? require special tools or special procedure of some sort?
Old Nov 8, 2003 | 07:17 PM
McFly's Avatar
Default Re: valve stem seals? (00b18b)
It requires removal of the cams and there is a special tool used to remove the valve springs. You will need compressed air to keep the valves from falling into the cylinders. This is assuming you are doing it on the car.
Old Nov 8, 2003 | 07:27 PM
00b18b's Avatar
Default Re: valve stem seals? (McFly)
actually i have the cams out and head off the block.
Old Nov 8, 2003 | 07:47 PM
McFly's Avatar
Then you have to use a spring compressor to remove and reinsrall the valve springs. Pull the valves through and pull the valve seals off with vice grips. Reinstall new seals with a small socket making sure you do not damage the sealing surface of the new seals. That is how I did mine. The spring compressor I have looks like this http://www.toolsource.com/ost1...Q2BFD
Old Nov 21, 2003 | 11:08 AM
Ryan C's Avatar
make sure you get the right tool to pull the seals, its a pain if you dont, trust me
live4soccer7
17
Jul 1, 2019 06:44 AM
lude98SH
Jul 26, 2007 05:39 AM
DanishR
Mar 3, 2006 12:00 AM
sleepin91teg
Jun 20, 2004 05:34 AM
ltho1998
Aug 3, 2003 05:45 PM
