d15 or d16 turbo or B20 non vtec
Old Mar 11, 2004 | 06:38 AM
civic5483's Avatar
Default d15 or d16 turbo or B20 non vtec
I have a 92 hatch and wanna do a swap.Should I go d15b d16 turbo or b20 non vtec with b16 trans? Eventually in the summer I'll put a vtec head on the b20 if I get that.Which is more reliable and powerful>
Old Mar 11, 2004 | 06:43 AM
boostsohfast's Avatar
Default Re: d15 or d16 turbo or B20 non vtec (civic5483)
This must be post #23842387 of dohc vs. sohc. I'm not tryin to be a dick but you can find a lot of info if you search.
I personally would go dohc if I had the money. SOHC's are cheap and fun as hell when their turbo'd... Even if you break something parts are really cheap. I know cause I have one, but there isn't a day that goes by where I wouldn't rather have a dohc.
Old Mar 11, 2004 | 09:00 AM
jerbear!'s Avatar
obviously the b20 is more reliable. :D
Old Mar 11, 2004 | 09:06 AM
8200RPM's Avatar
local hippie
Default Re: (jerbear!)
not.
go d-series turbo
Old Mar 11, 2004 | 09:10 AM
specv5150's Avatar
Default Re: d15 or d16 turbo or B20 non vtec (boostsohfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast &raquo;</TD></TR><TR><TD CLASS="quote">This must be post #23842387 of dohc vs. sohc. I'm not tryin to be a dick but you can find a lot of info if you search.
I personally would go dohc if I had the money. SOHC's are cheap and fun as hell when their turbo'd... Even if you break something parts are really cheap. I know cause I have one, but there isn't a day that goes by where I wouldn't rather have a dohc.</TD></TR></TABLE>
Yeah I want to turbo my D16 and I am in the process of doing a DIY setup but an H22 DID cross my mind. The deciding factor was cost. I figured after buying the H22, axles, clutch, shift linkage,etc etc I would be well over 3000. With my projected budget on ym turbo setup, I am looking at around 1800.
yUNgDRAGER510
26
Feb 26, 2014 09:34 AM
hbboostman
Apr 12, 2007 03:33 PM
boostincoupe
Acura TL, RL & ZDX
21
Feb 14, 2005 06:03 AM
PowderB16
Feb 11, 2005 09:26 PM
