VAFC or Hondata for the following setup...
Old Mar 11, 2004 | 04:06 AM
rizen's Avatar
Default VAFC or Hondata for the following setup...
SMSP header
SMSP high-flow cat
SMSP Exhaust
Jun2/ITR Cam Combo
Skunk2 Camgears
Now, I know that the Hondata is a better tuning solution over the VAFC. However, I want to know if the power I'll get with the Hondata over the VAFC will be significant enough that the price difference won't matter. In other words... with such a mild setup, is it worth going with the Hondata?
Old Mar 11, 2004 | 04:23 AM
Jon D's Avatar
Default Re: VAFC or Hondata for the following setup... (r1zen)
With your current set-up a vafc isnt going to do much. If you plan on doing more to your motor which seems quite possible then you had mise well just save the money you would spend on your vafc and get a hondata. You'll thank yourself if you do so.
Old Mar 11, 2004 | 06:29 AM
Rollo Lawson's Avatar
this is what i tell people....if you don't want the Hondata, think of what the cost of other tuning devices will cost. vafc-$200, fpr-$50, guage-$30, chip for your ecu-$75. and, after you buy all of those parts, you still can't adjust your redline or re-map any of your timing tables. you can only alter fuel. if anything, buy it, but don't install it until you've decided what more you want to add to your set-up. ooops...i didn't notice the JUN/ITR cam combo or the SMS header. ****, buy that Hondata and some injectors, fast.
Old Mar 11, 2004 | 06:51 AM
kshymkiw83's Avatar
Default Re: (B16C1)
That new Greddy system or the AEM EMS. Cost as much as the Hondata in the long run from what i have seen
Modified by kshymkiw83 at 4:00 PM 3/11/2004
Old Mar 11, 2004 | 07:09 AM
Splat's Avatar
Collector-o-Guns and Drinker
A well-tuned V-AFC would certainly help. Hondata would help more, though.
Old Mar 11, 2004 | 07:10 AM
rizen's Avatar
Default Re: (B16C1)
I was wondering If I was going to need injectors. Hrm...
Old Mar 11, 2004 | 07:11 AM
Bbasso's Avatar
Hondata will have more to work with and therfor will yeild more results.
Old Mar 11, 2004 | 08:08 AM
Finland's Avatar
Default Re: VAFC or Hondata for the following setup... (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Hondata will have more to work with and therfor will yeild more results.</TD></TR></TABLE>
Old Mar 11, 2004 | 10:13 AM
RGoose18's Avatar
Default Re: VAFC or Hondata for the following setup... (boost psycho)
Have you ever thought about an AEM EMS?
They're quite an easy install and more tuner friendly
Old Mar 11, 2004 | 01:06 PM
rizen's Avatar
Default Re: VAFC or Hondata for the following setup... (RGoose18)
As mentioned earlier, I'm probably going to need injectors as well. Is this necessary? If so, what are the best bang for the buck.
sleep
24
Feb 26, 2004 04:20 PM
sleep
15
Feb 11, 2004 03:30 PM
daddymaxx
Nov 21, 2003 12:44 PM
Teal95Coupe
Apr 4, 2003 03:04 PM
G3gsr
Feb 6, 2003 08:37 AM
