DA Radiator VS ITR Rad
Well im in kind of a bind. When was doing my jdm front end i accidently put a drill bit through one of the fins and have a 1*1 mm hole in it, it can be fixed but i dont know if i can trust it or not. I have a DA LS parts car and i put the rads side by side and they seem exactly the same size(except the two bottom mounts, but can be modified to fit). I was wondering if it had the same cooling charachteristics as the ITR rad. The LS rad seems to have more deepth and beefier than the ITR rad.
So two options i have are to replace the rad with the LS rad, or get the stock ITR rad fixed.
This is only a temoparary replacement till i can afford a C&R rad.
Re: DA Radiator VS ITR Rad (BlazeONE)
the opnly big diff is the bottom mounts, you can drill out the mounts and reweld them on where you want them . it should cool fine, i run a civic rad on my turbo R
jdmekcivic2eg
07-09-2004 01:44 PM
