Turbo on a 100k Civic?
Old Mar 10, 2004 | 09:32 PM
BBailey's Avatar
Default Turbo on a 100k Civic?
My 95 Civic EX has almost 100,000 miles on it... Would it be a waste to add turbo now or a harm? At what milage should I watch out for all the racing mods I added or want to add?
Old Mar 10, 2004 | 09:35 PM
willahlborn's Avatar
Default Re: Turbo on a 100k Civic? (BBailey)
I would say just turbo it, tune it, and run it until your engine dies. At least you'll have all the stuff you'll need to turbo the new motor after that. IMO if you're even thinking about turboing a Civic, you're not expecting the engine to last forever like a stock engine would.
me<===turboing my 150k mi d15b7
Old Mar 10, 2004 | 10:27 PM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BBailey &raquo;</TD></TR><TR><TD CLASS="quote">My 95 Civic EX has almost 100,000 miles on it... Would it be a waste to add turbo now or a harm? At what milage should I watch out for all the racing mods I added or want to add?</TD></TR></TABLE>
Do a compression check and go from there. If they are consistent and not too low then you are good to go.
If you are due for a major tune up then make sure you do all of those things before going turbo. Water pump, timing belt, replacing all fluids etc.
I am 100k+ turbo &lt;---------------------
Old Mar 10, 2004 | 10:34 PM
Rod.'s Avatar
Default Re: Turbo on a 100k Civic? (psileepR)
I put a turbo on 140,000 ls motor.
Old Mar 10, 2004 | 10:44 PM
.::Lee::.'s Avatar
Default Re: Turbo on a 100k Civic? (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">I put a turbo on 140,000 ls motor.</TD></TR></TABLE>
ditto but it's a z6
You may blow a head-gasket in time, other than that, if you do it right you'll be ok.
Old Mar 10, 2004 | 11:31 PM
NOSpeed97's Avatar
My D16Y7 had 140K on it when I slapped a turbo it and has been running strong for about 3.5 months now.
A friend boosted his D16A6 with, I think, about 150-160K on the clock.
Old Mar 10, 2004 | 11:46 PM
lazerus's Avatar
Default Re: Turbo on a 100k Civic? (NOSpeed97)
it just alll depends on how well its been serviced, and what kind of oils have been in it
compression checks can usually tell you the overall condition of the motor, as well as how bad oil is coked inside the cylinder head....
Old Mar 11, 2004 | 05:21 AM
ITSTOCK's Avatar
Default Re: Turbo on a 100k Civic? (lazerus)
Just do a compression check. If your not burning considerable amounts of oil or any weird noises coming form your engine then boost away.
My boosted d15b7 has 169k miles
Old Mar 11, 2004 | 05:28 AM
boost junky 71's Avatar
Tubro that 95 civic. My car had 128,000 on it when I went turbo.
Old Mar 12, 2004 | 10:51 PM
filipinium's Avatar
i turboed my 94 civic at 108k miles, it now has 149k miles on it...still kicken.
Old Mar 13, 2004 | 05:32 AM
cccya's Avatar
Default Re: Turbo on a 100k Civic? (filipinium)
190k and about to but boost to it
Old Mar 18, 2004 | 08:32 AM
BBailey's Avatar
Default Re: Turbo on a 100k Civic? (cccya)
Find out how much shipping is and hit me up on that hood.. i need a hood asap. What is better boost.. nos or turbo? And what is safer?
Old Mar 18, 2004 | 09:54 AM
99blusi's Avatar
I put my turbo on at 85k and I've got like 95K now still running strong. But, I did compression checks often (nitrous before the turbo went on) and I knew my motor was in prestine condition.
Old Mar 18, 2004 | 10:27 AM
G
sh!t happens.
Default Re: Turbo on a 100k Civic? (99blusi)
i got a 167k on my motor... and it stil runs..
Old Mar 18, 2004 | 04:26 PM
RobbieG35's Avatar
12 Years Strong
Default Re: Turbo on a 100k Civic? (G"UNIT)
(i got a 167k on my motor... and it stil runs..)
After lots of motor and nitrous abuse also
Perkul8r
15
May 11, 2009 02:00 PM
Joegt
Honda Civic (2001 - 2005)
Feb 8, 2007 06:25 PM
lilCivic
11
Jun 11, 2004 08:21 PM
cvcc
Dec 26, 2002 02:44 PM
