copper gasket spray?
Old Mar 10, 2004 | 07:20 PM
jdm_redneck's Avatar
Default copper gasket spray?
I was just curious if anyone has had any experience with using copper gasket spray on headgaskets. I was planning on disassembling my factory headgasket, making it a 2layer.
Old Mar 10, 2004 | 07:31 PM
SpoonyGSR's Avatar
I hate rap music
i use the copper spray, i always have.. works fine.
Old Mar 10, 2004 | 07:41 PM
dmotoguy's Avatar
Default Re: (spoonie_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonie_GSR &raquo;</TD></TR><TR><TD CLASS="quote">i use the copper spray, i always have.. works fine.</TD></TR></TABLE>
me too
Old Mar 10, 2004 | 08:37 PM
thad
Guest
Posts: n/a
Default Re: (dmotoguy)
copper spray
just use a new gasket
Old Mar 10, 2004 | 09:13 PM
AzG35's Avatar
Default Re: (thad)
I always you copper spray on my head gaskets. Just make sure the spray dries some before you bolt the head on. When it dries, it gets more tacky.
Old Mar 10, 2004 | 09:52 PM
b19coupe's Avatar
Default Re: copper gasket spray? (jdm_redneck)
I started using copper spray about two or three rebuilds ago. Good stuff
Old Mar 10, 2004 | 10:10 PM
Eddiebx's Avatar
i hope u get a new headgasket and then pull the middle lawyer out, dont reuse ur old one. You really dont need coper spray on stock gaskets, even if you pull the middle layer out, but i just squirt it between teh two layers for ***** and giggles. I dont use it on the outer sides that mate with the head and block.
Old Mar 16, 2004 | 07:19 PM
alfee's Avatar
Default Re:
which kind of copper spray is best? just go to any autozone/napa/kragens and ask for copper spray????
Old Mar 16, 2004 | 07:36 PM
b19coupe's Avatar
Default Re: Re: (alfee)
Permatex.
Old Mar 16, 2004 | 07:43 PM
drPepperStyles's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">I dont use it on the outer sides that mate with the head and block.</TD></TR></TABLE>
anyone else??
BodyKits NW's Avatar
Default Re: Re: (b19coupe)
I always use copper spray when installing a new gasket. Good stuff.
Old Mar 16, 2004 | 09:37 PM
Eddiebx's Avatar
Default Re: (drPepperStyles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drPepperStyles &raquo;</TD></TR><TR><TD CLASS="quote">
anyone else??</TD></TR></TABLE>
i've actually ran a stock gasket with the middle pulled out straight up, w/o any spray, for a good 10-15k and it held up fine as well. I put copper spray on the last one i put in, cuz i nicked the coating on one side slightly, so i just wanted to be safe than sorry.
The most important thing is to retorque ur head studs after you've ran your car through a few heat cycles. they do get loose
YoungMoney_Twit
Jul 8, 2018 10:11 PM
cfwthb_94
Aug 17, 2009 07:48 PM
1990si
Jul 19, 2006 01:28 PM
firstgenrex
Sep 24, 2003 08:37 AM
Westrock2000
Feb 15, 2003 01:00 AM
