PLEASE HELP!!! valve adj nut fell into oil flow hole!!!
Old Mar 10, 2004 | 01:57 PM
bluecb7's Avatar
Default PLEASE HELP!!! valve adj nut fell into oil flow hole!!!
While doing some maitenance on my head, i was screwing on the LAST valve adj. nut, when it slipped and fell into this hole: (Engine is H22A)
All I heard was it bouncing around and then drop onto something metal, AHHHHHHH!!!!!!! I was done with everything, goddamn it!!!!!!!
Did this nut fall into the oil pan???? I need to know, PLEASE HELP!!!
Modified by bluecb7 at 5:53 PM 3/14/2004
Old Mar 10, 2004 | 02:09 PM
SearchBeforeUPost!'s Avatar
Default Re: PLEASE HELP!!! valve adj nut fell into oil flow hole!!! (bluecb7)
go get a magnet on a stick, can be purchased at autozone or similar store.
I guess you can't see it at all?
Old Mar 10, 2004 | 02:19 PM
bluecb7's Avatar
Default Re: PLEASE HELP!!! valve adj nut fell into oil flow hole!!! (SearchBeforeUPost!)
Thank you sooo much, I was afraid It was going to take alot more to get to it.
Old Mar 10, 2004 | 02:35 PM
luder94-ChrisA's Avatar
definitely in the oil pan.... first try with the magentic stick down the hole....if that doesn't work, drain your oil & try using a magnet on the outside of the oil pan in a sweeping motion towards the hole...you might be able to get the nut out the hole without taking the pan off...if neither of those work, just take the oil pan off & it will be right there
Old Mar 10, 2004 | 02:37 PM
glad to help a fellow h22 powered cb7 owner out!
Old Mar 10, 2004 | 03:10 PM
3gdude's Avatar
Same thing happened about a month ago to a member of Honda-Tech.....Dont remember who.......3gdude
Old Mar 10, 2004 | 07:19 PM
tuan...'s Avatar
Default Re: PLEASE HELP!!! valve adj nut fell into oil flow hole!!! (3gdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3gdude &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happened about a month ago to a member of Honda-Tech.....Dont remember who.......3gdude</TD></TR></TABLE>
hahaha THAT WAS ME!! my nut fell onto the baffle plate thing. so draining your oil and stickin a magnet in it prob wont get it, unless your lucky. i had to take off my oil pan and pull off the baffle thing to get it (could of jus reached my hand in and picked it out, but i didnt know where it was)
BTW: if your an h22a4, its gonna be a pain in the *** to get ur oil pan off cus of all that hondabond (at least it was for me). they dont make regular gaksets for a4's u gotta use hondabond..
Old Mar 14, 2004 | 04:53 PM
bluecb7's Avatar
IT LIVES!!!!!
With the exception of an exhaust leak from a broken gasket, my engine is running perfectly, no ticking from LMA's sticking, and it purrs baby, yeah!!!!
One thing that scared me is that I found an extra valve adj nut in the oil pan . So now I have one extra valve adj nut. and a new oil pan gasket. The old one was a bitch to get off, it was caked on there like nothing I've ever seen. Had to work on it for like an hour But it's done and everything is good. Thanks for your guy's help.
Old Mar 14, 2004 | 06:58 PM
tuan...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluecb7 &raquo;</TD></TR><TR><TD CLASS="quote">IT LIVES!!!!!
One thing that scared me is that I found an extra valve adj nut in the oil pan . So now I have one extra valve adj nut. and a new oil pan gasket. The old one was a bitch to get off, it was caked on there like nothing I've ever seen. Had to work on it for like an hour But it's done and everything is good. Thanks for your guy's help.</TD></TR></TABLE>
heh talk about deja vu.. i jus recently got my car running too. also have an exhaust leak. valves still tick... wat are torque specs on those damn things.
Old Mar 14, 2004 | 07:43 PM
Variable J's Avatar
Default Re: PLEASE HELP!!! valve adj nut fell into oil flow hole!!! (h22a4_dc2)
autozone sells engines? I never knew that huh.
Old Mar 14, 2004 | 10:37 PM
bluecb7's Avatar
14 ft/lbs on the H22A, not sure if it differs on the a4, try to find a helms quote
Old Mar 14, 2004 | 10:39 PM
bluecb7's Avatar
Default Re: PLEASE HELP!!! valve adj nut fell into oil flow hole!!! (Variable J)
hell no man, read it again, IAVC for sale
Old Mar 19, 2004 | 11:55 AM
speedminded's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Variable J &raquo;</TD></TR><TR><TD CLASS="quote">autozone sells engines? I never knew that huh. </TD></TR></TABLE>
Actually they do, I doubt crate Hondas though but you never know.
Old Mar 19, 2004 | 02:20 PM
Honda Sport's Avatar
so how'd you get it out? took off the oil pan?
Old Mar 24, 2004 | 08:51 AM
bluecb7's Avatar
Default Re: PLEASE HELP!!! valve adj nut fell into oil flow hole!!! (Honda Sport)
Yeah, dropped the oil pan, replaced gasket, cleaned oil pan, sealed back up with hondabond, and presto, new oil pan gasket and a lost valve adj nut.
Old Mar 24, 2004 | 10:18 AM
was there a lot of gunk in the bottom of your oil pan?
Old Mar 24, 2004 | 11:46 AM
bluecb7's Avatar
Default Re: (Honda Sport)
Nope, only oil, why do you ask?
Old Mar 24, 2004 | 12:36 PM
flyrod's Avatar
Default Re: (bluecb7)
Thanks for letting us know how it went. Seems like most people never post back...
Old Mar 25, 2004 | 08:54 PM
bluecb7's Avatar
Default Re: (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for letting us know how it went. Seems like most people never post back...</TD></TR></TABLE>
So true, only like 1 out of ten people post back results nowadays after trying out the board's suggestions. Always gotta follow through, in anything you do, or else you're just lazy and don't wanna make the effort [/endrant]
Old Mar 25, 2004 | 09:12 PM
vinuneuro's Avatar
how hard is it to get to the oil pan to take it off? Do you have to remove that one cross member? Support the engine, **** like that?
Old Mar 25, 2004 | 09:22 PM
bluecb7's Avatar
Default Re: (vinuneuro)
Well, you do have to remove the main crossmember down there, the one that goes underneath it by the header, and also the bottom portion of the header. Make sure to replace your oil pan gasket, and also make sure to remove your oil dipstick, I bent mine while dropping it
Old Mar 28, 2004 | 03:46 AM
danmanh22's Avatar
haha too bad i didnt find this post sooner. i never though to look to honda-tech in times of severe need.
the exact f*ing thing happened to me a week ago when i was doing a valve adjustment. guess im not the only clumsy one...no wait, maybe i am cuz i got oil in one of the cylinders haha heres the thread:
https://honda-tech.com/zerothread?id=807287
the nut fell in, and my heart skipped a beat. i felt around with a magnet and didnt get jack &gt;&gt;&gt; i had to pull the oil pan. i was on a deadline with 6 hours left to go, so i pried that sucker off. helms and other manuals say you cant, but its not to terrible on h22s - the drivers side corner closest to the back of the car has a small tab that is recessed - a little bit away from the contact surface of the oil pan. after some horsing around trying to get it off, a call to a honda-tech buddy revealed that prying wouldn't do any damage (it will only damage when you actually pry the contact surface, which NEEDS to be perfect), and away i went with my prybar.
pulled the pan off, and voila - more magnet work in the baffle plate found that sucker no problem.
saturday late evening revealed that all of the honda parts places were closed, so my best friends of autozone ( i love autozone ) got a visit from me. they didnt have gaskets for a 2000 prelude. i nearly cried, but wait ((( lightbulb goes on ))) "Do you have a gasket for a 95 prelude vtec"? "Why yes, we do" haha
few hours later (with a perfectly fitting oil pan gasket, might i add) lude smokes 1.8t 20th anniversary gti, a modded base rsx, and a few older gti's while horsing around haha. thank you autozone!!!
nrraiders35
May 16, 2013 12:00 PM
slugo10
Nov 30, 2008 06:44 PM
realis9
Sep 18, 2008 06:53 PM
bluecb7
Mar 15, 2004 11:53 AM
bluecb7
Mar 14, 2004 04:51 PM
