b18cR (11.3:1 cr/ spoon spec) in a '88 crx si... what program for the pr3 or pw0?
Old Oct 17, 2001 | 07:06 PM
Black R's Avatar
25 Year Member
Default b18cR (11.3:1 cr/ spoon spec) in a '88 crx si... what program for the pr3 or pw0?
Ok, there must be someone who has done this swap before...
Where to get the ecu chipped?
Locash?
zdyne?
hondata?
I need something cheap for basically a jdm itr motor... cr is a little higher but that's it...
Old Oct 17, 2001 | 07:21 PM
FSTASNTZ's Avatar
Default Re: b18cR (11.3:1 cr/ spoon spec) in a '88 crx si... what program for the pr3 or pw0? (Black R)
James Boyer did the USDM B18C5 into his 94 Civic Coupe and used EL Prototypes. If you can find a Hondata dealer, have them strap it to the rollers and burn you one.
You could always get the USDM ITR program and back off the timing at the distributor, IF NEEDED...
Jason
Old Oct 18, 2001 | 08:06 AM
Trey's Avatar
25 Year Member
Default Re: b18cR (FSTASNTZ)
The Locash, Kenji, Katman spec programs will work for you. Check with them and they can help you. Runs about $250 last time I checked.
Old Oct 18, 2001 | 03:40 PM
Red Civic T's Avatar
New User
Default Re: b18cR (Trey)
I got Locash modded PR3 for 170 incl VTEC x-over switch modded to 5k rpm.
Old Oct 18, 2001 | 03:41 PM
New User
Default Re: b18cR (Red Civic T)
I got the Mugen clone.....
Old Oct 19, 2001 | 12:43 AM
Newman's Avatar
New User
Holy expensive! I sell/chip ECUs for almost half that.
As for what programs, I personally like the Mugen PR3 program (PYR PR3 is ok), or the Spoon PW0 program (FEEL's is very similar).... I have all 4 if interested
Old Oct 19, 2001 | 07:06 AM
Stinkalope's Avatar
New User
I have a B16 running a jdm spoon pr3 now. If I swapped a b18c5 longblock in, would the spoon ecu be holding the motor back at all??
HybridFiend
Mar 11, 2004 12:00 AM
jdmda6teg
Jan 20, 2004 09:32 PM
electron-eg
Nov 10, 2003 05:32 PM
EG3-R
Sep 9, 2002 09:28 AM
