Easy way to take off window tint???
Old Mar 9, 2004 | 08:44 PM
JdmLsPwr425's Avatar
Default Easy way to take off window tint???
Well, i bought my car with tint on it... and i dont like it at all.. i brought it to a tint shop and they tried to charge me $70 just to take off the tint... i thought that was CRAZY... so i was wonderin how do u take off window tint??? i heard u need a heat gun or sumthing...but ya.. please help me out, thanx!!!
Old Mar 9, 2004 | 08:51 PM
Forgiven's Avatar
Default Re: Easy way to take off window tint??? (JdmLsPwr425)
Usually, tint shops just peel the tint off, then spray warm soapy water, then let it soak, and either use a brillow pad or a razor blade to remove the glue. Just be careful on the back glass not to srape the lines for the defroster off. Anyone know a good way to get the tint off of the back glass off?
Old Mar 10, 2004 | 05:31 AM
jay_powell's Avatar
spray the back window with a glass cleaner based with amonia..then cover the back window with black garbage bag and put car in the sun for few hours..when you pull off the garbage bag most of the tint should come with it
Old Mar 10, 2004 | 05:35 AM
Auto Solutions's Avatar
You may also want to make sure the glass is at least warm. If you are in a cold area, may want to use a blow dryer to help you out. Cold tint comes of SLOW.
Old Mar 10, 2004 | 07:43 AM
hyper em1's Avatar
Default Re: (jay_powell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay_powell &raquo;</TD></TR><TR><TD CLASS="quote">spray the back window with a glass cleaner based with amonia..then cover the back window with black garbage bag and put car in the sun for few hours..when you pull off the garbage bag most of the tint should come with it</TD></TR></TABLE>
That is how most tint shops will remove the back window tint.
$70.00 is probably an average removal price for 3-5 windows
Old Mar 10, 2004 | 10:35 AM
frost_0ne's Avatar
Default Re: (hyperdecalsdotcom)
i just bought a integra from a mexican guy MEXICANS LOVE TINTED WINDOWS but wat i did i took a razer blade with like this holder thing and i scraped it off when i scraped that all off there was a sticky residue so i put some LAQUER THINNER on a rag and whipped it all off.came out crystal clear
Old Mar 10, 2004 | 12:15 PM
2trix's Avatar
Default Re: (frost_0ne)
what did you use to put the back window back in!? i went to schucks and they have window silicone but it says its not for mounting glass...maybe i should just goto a real window place and get some silicone..
Old Mar 10, 2004 | 12:16 PM
vtecb20coupe's Avatar
B A N N E D
Default Re: (2trix)
denatured alcohol.
Old Mar 10, 2004 | 05:56 PM
hyper em1's Avatar
Default Re: (2trix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2trix &raquo;</TD></TR><TR><TD CLASS="quote">what did you use to put the back window back in!? i went to schucks and they have window silicone but it says its not for mounting glass...maybe i should just goto a real window place and get some silicone..</TD></TR></TABLE>
you took the window out?
Old Mar 10, 2004 | 07:34 PM
HiRevn's Avatar
Try mixing some water and ammonia, put it in a spray bottle, spray it on and let it soak in for a little bit, then scrape it off with a blade. Be careful when doing the rear window. You don't want to damage the window defrosters with the blade.
1993ludevtec
Mar 22, 2004 03:19 PM
batman21
Jan 25, 2004 08:17 PM
civicracer99
Audio / Security / Video
Aug 26, 2003 03:11 PM
integra15
Aug 9, 2003 12:28 AM
LOWLIFEHATCH
Aug 20, 2002 07:25 AM
