Why do people rag on Drag Manifolds?
Old Mar 9, 2004 | 10:40 AM
jdmjay04
Guest
Posts: n/a
Default Why do people rag on Drag Manifolds?
I havent used one . Does anybody actually have pics of a cracked drag manifold? Or is it all he said she said bull? Dont they have warranty on them?
Modified by jdmjay04 at 8:54 PM 3/9/2004
Old Mar 9, 2004 | 11:00 AM
Mad Cow's Avatar
Default Re: Why do people rag on Drag Manifolds? (jdmjay04)
2 Reasons:
1. They crack.
2. Wastegate placement isn't optimal.
I don't have pictures of mine, but it cracked in two places and I welded it back up.
Old Mar 9, 2004 | 11:11 AM
808b18c1boosted's Avatar
Had mine for a almost 2 years no problems yet.The kit on my stock gsr put out 259.9whp 191.2tq till i can get a lovefab.
Old Mar 9, 2004 | 11:16 AM
Rod.'s Avatar
Default Re: Why do people rag on Drag Manifolds? (MadCow)
my first manifold was cracked. It cracked everywhere and someone welded it up. Then it held a lil then started cracking again. Then went to Jotech bought a revhard. Not the best but still hasnt cracked
Old Mar 9, 2004 | 12:48 PM
iiilgsrlll's Avatar
Default Re: Why do people rag on Drag Manifolds? (redturbocivic)
My Gen 2 manifold cracked everywhere possible. Welded up one spot another one would pop up later. Not sure if the problems been fixed in the DRAG 3/4 manifolds but both of them I had spider-webbed where the logs met.
Old Mar 9, 2004 | 01:14 PM
Griffin@Camtech's Avatar
Default Re: Why do people rag on Drag Manifolds? (iiilgsrlll)
the design on the drag GEN 3 and 4 manifolds is MUCH better as far as cracking goes and if it does crack they replace it for free. the wastgate placement still sucks tho and has problems with gradual boost and boost spikes. I know alot of guys do some mild porting on that sport and they say it fixed the problems. also the deltagate isn't the best and this further hinders the placement of the wastegate
Old Mar 9, 2004 | 01:20 PM
Rory Breaker's Avatar
Exactly...it isnt the cracking as much as the wastegate placement which leaves much to be desired.
Not a huge deal, but not ideal. I havent seen any spiking issues with my 60mm exhaust on.
Old Mar 9, 2004 | 01:22 PM
JDMCRX's Avatar
Default Re: Why do people rag on Drag Manifolds? (newgsrdriver)
Man ive had mine all summer at 9psi not one prob love it and it clears A/C
Old Mar 9, 2004 | 01:52 PM
D-Man's Avatar
my drag gen 2 manifold is 4 years old,has over 40,000 miles on it and is on its second engine ..no problems here..
Old Mar 9, 2004 | 02:52 PM
Nextelbuddy's Avatar
Default Re: Why do people rag on Drag Manifolds? (D-Man)
i made 326 to the wheels on a drag manifold and im still using it. i plan on making 450-500 witrh this manifold. of course im upgrading frag turbo and intercooler to bigger pieces
Old Mar 9, 2004 | 04:05 PM
SlowTeg's Avatar
Yup, the wastegate placement sucks. If there's a decent amount of backpressure you'll be fine. Just wait till you step upto a larger exhaust. A friend used to run a 3" dp and 3" exhaust and the lowest boost it could hold was a bar..
-Mike
Old Mar 9, 2004 | 04:21 PM
alpha's Avatar
My friend had a Drag manifold on his 2000 B18c5 2.5" downpipe flared to 3.0". It spiked from 9lbs to 15lbs. He went to an Inline Pro manifold (nothing else) and had no problem with the boost spiking.
Old Mar 9, 2004 | 05:08 PM
TurboR1391's Avatar
The thing about most people on Honda-tech is they go off here say alot and they tend to love the band wagon approach.
Old Mar 9, 2004 | 05:16 PM
alpha's Avatar
Default Re: Why do people rag on Drag Manifolds? (TurboR1391)
This wasn't hear say This happened multiple times in-front of VaporTrail, Enthalpy, some other people and I. I know VaporTrail and Enthalpy have seen it mroe than a couple times though.
Old Mar 9, 2004 | 05:22 PM
PureTeg420's Avatar
Default Re: Why do people rag on Drag Manifolds? (0x64)
Mine will hold boost with a 2.5"-3" dp and 3" exhaust, but if I run open downpipe it spikes to 15psi. No cracks though with 3 years of use, so I am happy
Old Mar 9, 2004 | 05:34 PM
Johnyquest's Avatar
Default Re: Why do people rag on Drag Manifolds? (PureTeg420)
I can run open DP on my drag gen 3 w/ t3 and my TiAL w/o any problems!!
Old Mar 9, 2004 | 05:54 PM
calib17a's Avatar
They could be cracking due to a lean condition or also due to no flex pipe on dp so as motor torques back there's no give in the the exhaust system. Mine has no cracks, been running for 6 months now. It made 259 whp 211 lbs, setup's in my sig. I'll be selling mine soon, just don't like they way it looks and upgrading the turbo so I got the inline pro manifold. I'll be running full race mani in near future.
Old Mar 9, 2004 | 10:28 PM
TurboR1391's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">This wasn't hear say </TD></TR></TABLE>Don't be so defensive. I know someone who had a a Drag Manifold crack, but it was on the old kit. If I offended you I'm sorry. You've been on Honda-tech long enough to know that most people on here go with the wind when it comes to opinions.
Old Mar 9, 2004 | 11:10 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCow &raquo;</TD></TR><TR><TD CLASS="quote">2 Reasons:
1. They crack.
I don't have pictures of mine, but it cracked in two places and I welded it back up. </TD></TR></TABLE>
Thats exacly the right answer to his question right there. I used to have one - didnt crack. But alot of people have. Id have to say the number of cracked manifolds are pretty low since there is about a billion drag manifolds in circulation.
Id say their biggest problem is the wastegate placement (ie off #1 runner). Its not optimal.
liam
Old Mar 10, 2004 | 03:16 AM
alpha's Avatar
I wasn't offended Just clearing up why I posted so no one would think another post about a "friend"
Old Mar 10, 2004 | 05:14 AM
D-Man's Avatar
Default Re: Why do people rag on Drag Manifolds? (calib17a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calib17a &raquo;</TD></TR><TR><TD CLASS="quote">They could be cracking due to a lean condition or also due to no flex pipe on dp so as motor torques back there's no give in the the exhaust system.</TD></TR></TABLE>
also..they could crack from not using the honda 2-piece exhaust manifold gasket...bolting it straight on with no gasket is a no no.
Old Mar 10, 2004 | 05:18 AM
JDMCRX's Avatar
Another thing for spiking people ive seen around here were using a deltagate wastegate. But as soon as they switch to a TIAL no probs.
I know that if i do a 3" exhaust with not cat it will spike. Im doing a 2.5"DP to a 3" exhaust and with a 3" cat i do not think ill have any probs i also use a TIAL waste gate.
Old Mar 10, 2004 | 06:17 AM
ek9turbo's Avatar
mine use to spike, went with tial wastegate it helped a little
but now i ported the runner where the wastegate flange is, it holds 14psi all the way to redline with open downpipe
no cracks yet
Old Mar 10, 2004 | 08:11 AM
alpha's Avatar
Default Re: Why do people rag on Drag Manifolds? (JDMCRX)
I forgot to mention he was using a TiAL 35mm.
Old Mar 10, 2004 | 12:55 PM
Default Re: Why do people rag on Drag Manifolds? (ek9turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9turbo &raquo;</TD></TR><TR><TD CLASS="quote">mine use to spike, went with tial wastegate it helped a little
no cracks yet</TD></TR></TABLE>
Do you have any pictures as to the extent of your porting?
