B16A transmission - will an ITR 4.4 FD and LSD fit?
Old Mar 9, 2004 | 08:21 AM
99 TYPE R's Avatar
Default Tranny ? 4.4 Final drive
Will an ITR 4.4 final drive fit in my 99 B16A2 transmission?
Any info is great, I tried to search... tried the all motor forum but no replies.
Old Mar 9, 2004 | 08:27 AM
Dan GSR's Avatar
Default Re: Tranny ? 4.4 Final drive (99CtRdAvESI)
will the gears mesh? yes
will it fit on your stock differential? no
will it change your gearing? no
Old Mar 9, 2004 | 08:28 AM
Dan GSR's Avatar
Default Re: Tranny ? 4.4 Final drive (Dan GSR)
if your intention is to put an itr lsd in your car , you will need the lsd and the final drive ring gear, and its basically a drop in
you may need to shim the motor for clearance
Old Mar 9, 2004 | 10:39 AM
99 TYPE R's Avatar
so if i buy the ring and the lsd it will lower my final drive , do u know what the final drive in my b16 is and it is a drop in u said ,what else would i have to get ,will it make a difference
Old Mar 9, 2004 | 11:25 AM
Dan GSR's Avatar
Default Re: (99CtRdAvESI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99CtRdAvESI &raquo;</TD></TR><TR><TD CLASS="quote">so if i buy the ring and the lsd it will lower my final drive , do u know what the final drive in my b16 is and it is a drop in u said ,what else would i have to get ,will it make a difference </TD></TR></TABLE>
wow
IT WILL NOT LOWER YOUR FINAL DRIVE
YOU MAY HAVE TO SHIM THE DIFF
only difference is that you have an lsd
Old Mar 9, 2004 | 11:29 AM
Chris N's Avatar
It's the same final drive, why do you want it?
Old Mar 9, 2004 | 12:47 PM
thad
Guest
Posts: n/a
Default Re: (Chris N)
the b16 final drive is 4.4, most of the b series trannies have 4.4 final drive, with the exeption of the b18b (4.2) and the type R (4.7)
Old Mar 9, 2004 | 12:50 PM
.RJ's Avatar
.RJ
Default Re: (thad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thad &raquo;</TD></TR><TR><TD CLASS="quote">the type R (4.7) </TD></TR></TABLE>
USDM Hype-Arrr is 4.4
Old Mar 9, 2004 | 12:53 PM
Chris N's Avatar
Default Re: (thad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thad &raquo;</TD></TR><TR><TD CLASS="quote">the b16 final drive is 4.4, most of the b series trannies have 4.4 final drive, with the exeption of the b18b (4.2) and the type R (4.7) </TD></TR></TABLE>
Holy crap. lol.
Thanks for correcting me, but I knew what I was talking about.
BTW - the B16 and B18c5 transmissions (both USDM) have the same gear ratios and final drive ratio.
And... The JDM Type R FD is NOT 4.7. It is 4.785.
Old Mar 9, 2004 | 03:07 PM
99 TYPE R's Avatar
all i want is type r lsd now can i just throw it in n u said shim the difference
Old Mar 9, 2004 | 03:10 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99CtRdAvESI &raquo;</TD></TR><TR><TD CLASS="quote">all i want is type r lsd now can i just throw it in n u said shim the difference </TD></TR></TABLE>
You really need to be clearer in your posts, otherwise its very hard to know what it is that you are asking. First you asked about a 4.4 Final drive, now you say you want the ITR LSD.
Yes you can just "throw it in" and you will need to check the clearance, the specs are in the helms manual.
Old Mar 9, 2004 | 03:13 PM
99 TYPE R's Avatar
ok guys sorry the post is complete i should have been more specific thanx
Old Mar 9, 2004 | 03:15 PM
.RJ's Avatar
.RJ
The more details and clearer you present your questions/posts, the better the answers/discussion you will get
Remember, garbage in....
Old Mar 10, 2004 | 08:22 PM
thad
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
And... The JDM Type R FD is NOT 4.7. It is 4.785.</TD></TR></TABLE>
i kinda knew it was gonna come to this, but WTF , sorry i didn't specify JDM or USDM and sorry i was unclear about the 4.785 FD as well as the 4.266 FD, i abreviated, ...my bad....
Gloomyz
25
Oct 31, 2016 10:33 PM
Er4sEr
Sep 7, 2007 12:02 PM
SkRiBLaH
10
Apr 28, 2006 08:28 AM
SupaFly_Honda
May 12, 2004 05:12 AM
sirminder
Sep 5, 2003 11:34 AM
