Hf manifold with external wastegate?
Old Mar 9, 2004 | 08:02 AM
4drEF's Avatar
Keyboard Humorist
Default Hf manifold with external wastegate?
Can it be done? Got pics?
Old Mar 9, 2004 | 11:29 AM
5STAR3's Avatar
Default Re: Hf manifold with external wastegate? (4drEF)
by the time you jimmy up something that probably wont work, you should have just bought a log style mani. its not easy to weld cast.
lovefab- $300
spoolinperformance ~$230 i think
check around and do it right the first time.
Old Mar 9, 2004 | 11:46 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Hf manifold with external wastegate? (envision2teg)
Yeah, I normally follow that rule "do it right the first time".
I have a used turbo, HF manifold, and the adaptor plate already. I bought them all through different sources. I bought the turbo knowing it didn't have the actuator for the internal wastegate so I'm now looking at options. I either get the actuator or I get a log with an external. The log alone costs more than I want to spend so I am down figureing out what else I can do. From your response it would seem that I will end up getting an actuator.
Old Mar 9, 2004 | 11:54 AM
5STAR3's Avatar
well i have an internal wastegate if you want it.
its all yours, $20 shipped. off a garrett t3 turbo.
Old Mar 9, 2004 | 12:12 PM
mikecivichb's Avatar
Is any type of pressure line supposed go onto that nipple? thanks
Old Mar 9, 2004 | 12:15 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Can it be done? Got pics?</TD></TR></TABLE>
Weld a flange on to the top of the hf manifold where the factory o2 sensor is now.. Put an external wastegate on there..
Old Mar 9, 2004 | 12:17 PM
5STAR3's Avatar
Default Re: Hf manifold with external wastegate? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
Weld a flange on to the top of the hf manifold where the factory o2 sensor is now.. Put an external wastegate on there..</TD></TR></TABLE>
not big enough, not easy to weld cast, as stated before. overal, not worth the investment.
Old Mar 9, 2004 | 12:42 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Hf manifold with external wastegate? (mikecivichb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikecivichb &raquo;</TD></TR><TR><TD CLASS="quote">Is any type of pressure line supposed go onto that nipple? thanks</TD></TR></TABLE>
Yes. That's the diaphram actuator I was talking about. The metal rod sticking out of it actuates a lever on the wastegate flap and makes it open when there is enough boost.
Old Mar 15, 2004 | 09:49 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">
not big enough, not easy to weld cast, as stated before. overal, not worth the investment.</TD></TR></TABLE>
I know its not easy to weld cast and may not be worth it.. The are at the top is big enough to put a flange on if you remove the factory o2 sensor there..
Old Mar 15, 2004 | 10:07 AM
5STAR3's Avatar
I know its not easy to weld cast and may not be worth it.. The are at the top is big enough to put a flange on if you remove the factory o2 sensor there..</TD></TR></TABLE>
1. it is not big enough.
2. even if it was how are you going to get it on there, JBweld? haha
Old Mar 15, 2004 | 10:23 AM
tgreaves's Avatar
2. even if it was how are you going to get it on there, JBweld? haha</TD></TR></TABLE>
Seems we disagree on this one.. I wouldnt jbweld it but im pretty sure it can be welded by other mean.. And I think that is it big enough, There is a pretty good area there and I have put a tial 35mm wastegate flange on top of the hf manifold that I have and there is room for it..
Old Mar 15, 2004 | 08:12 PM
fsp31's Avatar
A decent welder can definitely weld cast. Especially if it's not a "weight bearing". IMO, there is room to put it on a HF manifold. And also (IMO) it would be a complete waste of perfectly good welding rod. Just slap a oem diaphragm on the internal WG and be done with it.
Small rant: People debate the merits of internal vs. external WG's quite a bit around here. Cracks me up since 99% of us will probably never see even 12 psi anyway.
Old Mar 15, 2004 | 08:51 PM
5STAR3's Avatar
Seems we disagree on this one.. I wouldnt jbweld it but im pretty sure it can be welded by other mean..</TD></TR></TABLE>
lol
i was kidding about the jbweld.
yes a GOOD welder can weld cast. But going through the extent of finding someone who will/can and preping the manifold for the welds..... you might as well just spend $200-250.
your right we do dissagree on this, so i will leave it at this.
IMO there is no reason to attemp this.
Old Mar 16, 2004 | 06:07 AM
tgreaves's Avatar
Default Re: Hf manifold with external wastegate? (jz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz &raquo;</TD></TR><TR><TD CLASS="quote">i have an idea if you wanna keep the hf manifold. that ***** pretty thick huh? how about you drill a hole about 40-42 mm in diameter (somewhere where you would want to put the wg) then tap it. then go get some threaded steel pipe (35 mm ID and 1/2''- 1'' in length) weld a wg flange on the other end of that and then screw the contraption into your threaded hole on the hf mani. and i guess it wouldnt hurt to put some jb weld on those threads either just to keep it in place. its worth a shot. </TD></TR></TABLE>
Thats actually a great idea.. I might even try this on my hf manifold..
jpo20
Mar 23, 2009 01:27 PM
bacnoonoi
Nov 12, 2008 06:56 AM
sasinorm01
Mar 14, 2008 08:14 PM
LostCRX
Dec 14, 2004 12:56 PM
1boostedcivic
Dec 2, 2004 02:13 PM
