New set-up on the way!!!
I THINK I've finally made up my freakin mind on my set-up!! Tell me what you think...how much to the spoolin performance mani/DP cost?...maybe u guys an help me out
Oh yeah its for a d16z6
Maxrev mani OR spoolin performance mani
Maxrev DP OR spoolin performance DP
T3 60 OR T3/To4b both .48 a/r
Greddy Intercooler set-up kit (type 31)
Tial 38mm WG
Greddy Type s BOV
Misc Vac lines
Oil feed/return kit by STAN
RC 440's
Hondata s200b
http://www.kteller.com 3" exhuast
I think that's it! I've been reading up ALOT on turbo hondas...SPECIFICALLY turbo D's...and I think this is a relatively good set-up. I'm shooting for around 200-225 HP...with room to upgrade once my engine gets built this summer. If I forgot anything let me know please! I was gonna go with the greddy kit since its my first kit...but i figured id spend money to have a 2.5" DP made...so why not just build a kit anyway
Tial 38mm WG
Greddy Type s BOV
Misc Vac lines
RC 440's
Hondata s200b
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedCivic94 »</TD></TR><TR><TD CLASS="quote">I THINK I've finally made up my freakin mind on my set-up!! Tell me what you think...how much to the spoolin performance mani/DP cost?...maybe u guys an help me out
Tial 38mm WG
Greddy Type s BOV
Misc Vac lines
RC 440's
Hondata s200b
You know what I've noticed? Everyone's building their SOHC's, and no one's posting dyno sheets of built SOHC's. Finish your **** up!
Tial 38mm WG
Greddy Type s BOV
Misc Vac lines
RC 440's
Hondata s200b
Might want to check your list against mine...everyone seems to initially forget a few hundred dollars worth of stuff when building their own turbo kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">WHAT I HAVE BOUGHT SO FAR
Lovefab Sidewinder Manifold [not recieved yet] - lovefab.com - $850
Thermal R&D 3" Stainless Cat Back Exhaust - importparts.com - $600
Turbonetics T3/T04E 60 trim w/ stage 3 wheel - hondaclassifieds.com - $460
Hondata S200B - hondata.com - $435
TiAL 40mm Wastegate [0.4 bar spring] - importparts.com - $330
20"x8"x2" FMIC [2.5" inlets] - 92HB_HB - $240
TiAL Blow Off Valve - extremepsi.com - $209
RC Engineering 550cc Peak & Hold Injectors - ebay.com - $200
Charge pipe materials [I bought too much ] - jcwhitney.com - $132
Oil Feed & Return Lines - fast-turbo.com - $125
Walbro HP 255lph Fuel Pump - $100
Carsound 3" Hi-Flow Catalytic Converter - importparts.com - $99
12" Slim Pusher Radiator Fan - 92HB_HB - $50
2' Length of 2.5" Silicone Hose - roadraceengineering.com - $50
TurboXS Manual Boost Controller - ebay.com - $65
Downpipe Materials - jcwhitney.com & jegs.com - $65
3" Flex Pipe - b18bturbo - $40
T3 Exhaust Flange - atpturbo.com - $35
P28 ECU - local seller - $30
T-Bolt Clamps - partssystems.com - $33
Silicone 2" to 2.5" Hose Connector - roadraceengineering.com - $23
Honda OEM Resistor Box - ebay.com - $15
Two o2 bungs - atpturbo.com - $10
o2 bung block off bolt - atpturbo.com - $5
WHAT I HAVE YET TO BUY
Radiator Hoses/Vacuum Hoses - $50 approx.
ECU Socketing - hondata.com - $65
Greddy Turbo Timer - evasivemotorsports.com - $85
Hondata Tuning - balanced performance - $300
Now who said boosting was cheap????</TD></TR></TABLE>
civicnar
Apr 16, 2006 11:42 PM
