help my DA sounds like a retarded dolphine
Old Mar 8, 2004 | 10:02 PM
[626]phixionEF91's Avatar
Default help my DA sounds like a retarded dolphine
ya my DA sounds stupid. like a dolphine periodiacally when im driving so embarassing and its driving me nuts.
my speculation is its a belt problem what do u guys think
the sound doesnt change or intensify with speed so im not sure WTF it is. if you guys can give me any sort of feed back that would be greatly appreciated.
for those of u who have glanced at this post i would like to thank u by submitted a URL of my favorite clip. peep this ninja
http://media.ebaumsworld.com/i...b.wmv
Old Mar 8, 2004 | 10:36 PM
JDMHN8's Avatar
Default Re: help my DA sounds like a retarded dolphine ([626]phixionEF91)
Try tightening the alternator belt. You'll need a 12mm wrench and some sort of long prying lever (a screwdriver, even better, a prybar). Loosen the adjusting nut on the upper alternator bracket, stick the prybar in between the alternator and the engine and give it hell. Then, tighten the nut while you've got pressure on it. You should be good to go. Make sure to really torque that nut so it doesn't slip...
I had a sound like this and it has yet to come back after I adjusted the belt...
Old Mar 8, 2004 | 10:46 PM
Default Re: help my DA sounds like a retarded dolphine (JDMDA9)
nice hommie a free fix it i like that man...
Old Mar 9, 2004 | 06:48 AM
Nino's Avatar
I see that you have a GS. If it's not the belts, check the ABS next. My ABS was making a weird noise like that and I ended up dis-engaging it and the noise went away.
-nino
Old Mar 9, 2004 | 07:15 AM
stasi's Avatar
Default Re: help my DA sounds like a retarded dolphine (Nino)
From your description, it sounds like a belt may be squeaking?
If that's the case, go buy some belt dressing ($2.00-4.00) and
spray the belts down (Alternator, A/C, power steering) and see
if it goes away.
Old Mar 9, 2004 | 07:57 AM
Creep's Avatar
Default Re: help my DA sounds like a retarded dolphine (stasi)
Does it happen all the time or in a certain gear?
Old Mar 9, 2004 | 08:04 AM
Type S's Avatar
Default Re: help my DA sounds like a retarded dolphine (Creep)
dont use the belt dressing, it will just wear the belts, trust me, i changed my alternator belt 3 times in 2 weeks because of it.
just tighten the alternator belt and that should fix it. or why not just change it for added security. the belt is only $12 and takes like 10-15 min to change
Old Mar 9, 2004 | 09:56 AM
Default Re: help my DA sounds like a retarded dolphine (Type S)
damn where is the alternator belt...
sorry i just switched back to hondas from vw's
oh and it doesnt matter what gear or speed its in...
Old Mar 10, 2004 | 12:00 PM
r34p3r666's Avatar
Also, check your dizzy ... Mine took a **** on me the other day, and was squeaking REAL bad, as the bearing inside gave out ... Fixed it for free though, as i had me little brother pull the dizzy off my spare (SUPER LOW MILES) engine ... I'm now looking into going intoa distributorless ignition setup ...
Old Mar 10, 2004 | 12:16 PM
mr.beeks's Avatar
Default Re: help my DA sounds like a retarded dolphine (r34p3r666)
if you tried your alternator belt
and dressing on all your belts
check your ac tension pulley and your power steering
pump.. see if its moving straight...
Old Mar 10, 2004 | 12:17 PM
florduhdude's Avatar
What side of the car is the sound coming from?
It's probably the ABS pump running if you have a GS and the noise is on the right side. They start sounding like this if they run too often. The ABS pumps on the DA are junk and not made for continuous use.
The pump isn't the problem though, it's either a broken accumulator or leaking modulator solenoids that are keeping the pressure from holding and so the pump kicks on all the time. The solenoids are probably an easy fix, just use your abs. Take it out the next time it's raining and stomp the brakes a few times to get it to engage. If you are lucky and it is leaking solenoids, any dirt or gunk that is keeping them from sealing will be flushed out. I'd change the ABS brake fluid too, odds are it's never been changed.
If none of this helps then it's probably the accumulator. They just go out eventually and you have to replace it, or deal with the dolphin sound getting worse until it eventually goes away and gets replaced by your ABS light!
Old Mar 11, 2004 | 10:30 PM
Default Re: help my DA sounds like a retarded dolphine (florduhdude)
the sound mysteriously dissapeared but ya it was coming from the passenger (right) side. i did notice the abs light go on for a hot sec a while ago. and i thought i needed new breaks until today when i looked at the pads. they looked fine. im guessing my abs system sux. i kinda want to remove it anyways
Old Mar 11, 2004 | 10:59 PM
Slain's Avatar
i removed my fuses for the abs..then just cut the wire for the dash indicator... no more wah wah wah wah noises. good luck
Old Mar 12, 2004 | 09:35 PM
Default Re: (Slain)
sound has returned what fuses control the abs??
Old Mar 12, 2004 | 10:11 PM
Slain's Avatar
its under the hood. its either two or three fuses from what i can remember
Old Mar 13, 2004 | 07:16 AM
Default Re: (Slain)
There are 3 15amp fuses in the middle of the enngine fuse box. They are right next to the big fuses. I'm guessing your fusebox label is long gone? You know your abs light is going to come on when you do this right?
Old Mar 13, 2004 | 03:34 PM
Default Re: (florduhdude)
ok ill give it a looksee
does anyone know how or how much it cost to remove the entire abs system
MyWhiteEJ6
10
Jul 21, 2013 05:44 PM
TehMoonRulz
Dec 8, 2008 09:28 AM
efyou
Feb 22, 2006 08:02 PM
Cooch2005
Sep 26, 2005 09:39 PM
zither
13
Jan 3, 2004 04:40 AM
