turbo'd b18c1 or c5's. I need your input
Old Mar 8, 2004 | 08:54 PM
vteckiller's Avatar
Default turbo'd b18c1 or c5's. I need your input
I am going to be turbo'd soon and have a quick question. what turbo did you choose? I have been searching and cant make my mind up. The two im really intrested in are the sc34 and sc61. Im looking to make 325-350 hp. I dont want alot of lag but i also dont want to be running 15+psi to make this power goal I have been leaning towards the sc61 with a/r .63 whhel trim 69 Do you think this would be good? I want to boost by 4000-4500. thnx
Old Mar 8, 2004 | 09:04 PM
m R g S r's Avatar
Default Re: turbo'd b18c1 or c5's. I need your input (vteckiller)
Search harder man, I would help you but theres too many threads about these turbos. BTW, You can easily make that power with both of those turbos.
Old Mar 8, 2004 | 09:22 PM
Type-ARR's Avatar
Default Re: turbo'd b18c1 or c5's. I need your input (m R g S r)
Get the 61, boost is like crack, once you get a hit you'll be begging for more and the 61 will be there to do it. . .
Old Mar 8, 2004 | 10:14 PM
pissedoffsol's Avatar
25 Year Member
if mid 300's are your goal, the sc61 is really too big.
the sc34, or even the sc50 will get you there, and sooner.
as for the motor, either or again. the gsr is plenty IMO. there's no need to spend 2k more on the itr swap.
R3JEKT
Feb 1, 2008 10:39 AM
EJ8 GSR-T
Oct 26, 2006 01:21 PM
3s0n3
Feb 15, 2006 08:24 PM
bigwig
Oct 4, 2003 10:23 PM
