How much does it cost to install a LSD unit.... and your 60ft times
Old Mar 8, 2004 | 06:47 PM
ApexiChild's Avatar
Default How much does it cost to install a LSD unit.... and your 60ft times
1) how much does it cost to install a Qauife LSD unit inside my gsr tranny?
How much gains should I get at the track?
2300lbs civic
tiens ss
13" lensos with M&H 22x 13 x 7.5
making 270whp with 220tq at 10psi
currently running 2.0 60ft times
jimfab bar
action 2MD
How much should I instantly knock off my time...? i would love to get 1.8 or 1.9 60ft times....
2) what are you FI guy running as in 60ft times
please just list
whp and tq
curb weight
tires
suspension (mounts, bushing, traction bars, shocks... ect)
tranny
THANKS fella I'm new here but not new to honda's
Old Mar 8, 2004 | 06:48 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: How much does it cost to install a LSD unit.... and your 60ft times (ApexiChild)
bump i'd like to know as well
Old Mar 9, 2004 | 04:36 AM
ApexiChild's Avatar
bump
I know there are more knowledgeable people out there that on clubsi or superhonda.. hahaha lOL
Old Mar 9, 2004 | 05:44 AM
Griffin@Camtech's Avatar
my setup is pretty much the same except 24.5x8x13 slicks w/ JDM LSD pulling 1.75 60fts thats leaving at 7000 RPMs w/12PSI on the slicks
Our shop sells the quaife for $880.00 and install them for $375.00 just to give you an idea.
Old Mar 9, 2004 | 06:25 AM
bxsi's Avatar
yea it works really well, type-r lsd works just as good from what i've seen but doesn't have that lifetime warrenty.
Anyway:
00' civic si
quaife lsd
244whp 172wtrq
2600lbs w/ driver
100% stock suspension
factory michlen tires w/ 30k on them 195/55/15
used to do 2.4-2.7 on average before lsd, now my best was a 2.19 but i average 2.20-2.35. I still **** up every now and then and pull 2.3+, but thats once in a blue moon not every run like it used to be.
Old Mar 9, 2004 | 08:15 AM
RyanEJ8's Avatar
Quaife also comes with a lifetime warranty.
Old Mar 9, 2004 | 08:43 AM
ApexiChild's Avatar
Default Re: How much does it cost to install a LSD unit.... and your 60ft times (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Quaife also comes with a lifetime warranty.</TD></TR></TABLE>
that's the best thing about it!
So i guess the adverage cost to install a unit is $300ish?
Old Mar 9, 2004 | 09:08 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApexiChild &raquo;</TD></TR><TR><TD CLASS="quote">
So i guess the adverage cost to install a unit is $300ish? </TD></TR></TABLE>
That's probably with the tranny already out, right?
Old Mar 9, 2004 | 09:43 AM
Trak_Day's Avatar
New User
My suggestions, find a how-to pull the tranny yourself and save a bit of money! then take it to the shop to have the lsd put in!
Old Mar 9, 2004 | 09:54 AM
nevin's Avatar
please just list
whp and tq
curb weight
tires
tranny
THANKS fella I'm new here but not new to honda's </TD></TR></TABLE>
whp and tq 159/195
curb weight around 2000
tires 20/8/14 mt
suspension gc coilover/agx front rear stock/ place mounts/ place xmember
tranny cable A1
1.8s every time
Old Mar 9, 2004 | 09:56 AM
nevin's Avatar
oh yeah open dif!
Old Mar 9, 2004 | 06:04 PM
dfoxengr's Avatar
Default Re: (nevin)
nevin what are your et's?
Old Mar 9, 2004 | 06:29 PM
ITSTOCK's Avatar
Maybe you should try using a bigger set of slicks?
Old Mar 9, 2004 | 07:37 PM
nevin's Avatar
Default Re: (hybridvteceg)
my best et was 8.3 @ 82 (8th) i belive
Old Mar 9, 2004 | 08:28 PM
dunkd's Avatar
why do ppl spend all this money on quife lsd's when they can get a type-r tranny for much cheaper?
Old Mar 9, 2004 | 08:31 PM
SiRkid's Avatar
Default Re: (dunkd)
because the type R lsd cant handle that much torque...
and the quaife can. the quaife also has a life time warranty.
id say the qauife actually helps you more for when the wheels are going diff speeds then off the line lol turning...
Old Mar 9, 2004 | 08:32 PM
buda18's Avatar
Default Re: (dunkd)
can the quiafe handle more tq or hp compared to the ITR?
i always thought that had something to do with it
Old Mar 9, 2004 | 08:52 PM
Bailhatch's Avatar
Default Re: (buda18)
Costs about $350 w/ the tranny out around here
Old Mar 9, 2004 | 09:41 PM
japrex's Avatar
yeah i would like to know how much hp and tq the stock honda LSD can handle wheather it be the type R LSD or any honda factory LSD.
Old Mar 9, 2004 | 11:07 PM
liam821's Avatar
25 Year Member
Default Re: (japrex)
Courtney (UglyAssCivic) runs 10s with an open diff and cuts 1.7-1.8s on 25" slicks. Same with Ron (60dash1).
Ive heard that you dont want to use a oem itr diff - they dont like to hold a ton of power. Your better off with an open diff for high hp applications.
Ive heard very good thigns about the Quaife. They are almost indestructible and come with a lifetime warrenty. They will warrenty the product under race conditions which is very awesome.
I have a Cusco LSD (clutch type) in my car - cant say much about it because i just put it in. But it looks to be of very good quality and very strong.
liam
Old Mar 10, 2004 | 03:24 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: (Bailhatch)
does that include new diff bearings pressed onto the new Quaife???????
I do ALOT of tranny work on the side for people, trying to figure out how much to charge. Since I don;t have a shop, I don't have the high overhead.
I usually charge about $25-30 hr, but I'm not a business YET!
kmaz93da
Jun 23, 2010 06:04 PM
crxste
Jun 10, 2003 09:50 AM
h huff
Jan 20, 2003 01:45 PM
MintyDip
Jun 4, 2002 04:17 PM
