lsd and 60 ft.
Old Sep 24, 2002 | 02:40 PM
h huff's Avatar
New User
Default lsd and 60 ft.
anyone have any 1st hand knowledge of their 60ft times before and after they installed a limited slip. i have heard many stories and opinions but i'm looking for some answers from people that have actually run their cars both ways.
Old Sep 24, 2002 | 02:48 PM
jinxproof99's Avatar
New User
Default Re: lsd and 60 ft. (h huff)
from personal experience......with drag racing, a lsd will improve your consistency through out the entire run as much as your actual 60 ft. alot depends on your set up. the more power your making the more it will help you. for instance, with 500 hsp, i spin far beyond the 60. having a lsd helps all the way through the first three gears. if your making good power, its worth the money.
Old Sep 24, 2002 | 08:29 PM
1 2 NV's Avatar
didnt change my 60s at all, but i pull better 60s than my friends do that dont have LSD.
Old Sep 25, 2002 | 01:40 AM
sparkz's Avatar
Default Re: lsd and 60 ft. (hondaatwsu)
never saw a decrease in 60ft times but it felt like launches were more consistent
Old Sep 26, 2002 | 11:58 PM
riceboy's Avatar
Default Re: lsd and 60 ft. (sparkz)
Most people I've talked to say that it dropped just a small amount off their sixty foots, but it made it easier to control at launch.
Old Sep 27, 2002 | 09:34 AM
armrslr's Avatar
I went from 2.6's and 2.7's to now running 2.2's and 2.3's, to me that makes a really big differnce. The main thing is that you have a much stronger differential and it is much more dependable!!!!!!!
Old Sep 27, 2002 | 09:50 AM
riceboy's Avatar
Default Re: lsd and 60 ft. (armrslr)
in what set up? That is quite a large drop in time.
Old Sep 27, 2002 | 11:15 AM
armrslr's Avatar
Default Re: lsd and 60 ft. (riceboy)
Well I forgot to add that I did that by also adding a completely built head with port and polish work done too
Old Jan 19, 2003 | 02:06 PM
Fuster_Cluck's Avatar
How about your over all 1/4 or 1/8th time w/ and w/o LSD?
I may just buy the GSR motor w/o LSD and when I rebuild it add LSD since it doesn't seem to make that much of a difference.....
Old Jan 19, 2003 | 03:44 PM
XLR8 GS-R's Avatar
Default Re: lsd and 60 ft. (Hybrid93Hatch)
Im getting the quiffe put in as we speek! My last time at the track i had like 2.5 60's. Cant wait to try it with my new setup.
Old Jan 19, 2003 | 05:58 PM
1 2 NV's Avatar
didnt change either. i ran mid 14s in my coupe w/ LSD and mid 14s w/o LSD. 1/8th mile times were consistent 9.3s on most days.
Old Jan 19, 2003 | 06:21 PM
jun-awd's Avatar
I saw a .2 improvement with an lsd
Old Jan 20, 2003 | 01:57 AM
Default Re: lsd and 60 ft. (jun-awd)
Thanks for the info on the times w and w/o LSD! Hybrid93Hatch now realizes he has $1,000 to spend elsewhere on the Hybrid
Old Jan 20, 2003 | 01:45 PM
JdmVetteEater
Guest
Posts: n/a
I have a sohc and i cut 1.98 with nitto streets... with lsd
kmaz93da
Jun 23, 2010 06:04 PM
racer76j
Transmission & Drivetrain
Mar 8, 2009 04:59 AM
deeweezy187
Dec 4, 2005 01:40 PM
austrian type-R
Aug 14, 2003 04:21 AM
