ls/vtec
Old Mar 8, 2004 | 06:19 PM
tegasaurus's Avatar
Default ls/vtec
got the head, got the ecu, got the head studs, got the new head gasket, got the dowels, got the oil lines
now for the electrical part. What do i do? haha i know exactly how to do the headswapage, but how do i wired everything up?
Old Mar 9, 2004 | 01:49 AM
tegasaurus's Avatar
Default Re: ls/vtec (tegasaurus)
for the love of god
Old Mar 9, 2004 | 12:53 PM
dfoxengr's Avatar
use a gsr harness or add a few wires
Old Mar 9, 2004 | 08:52 PM
Rod.'s Avatar
Default Re: ls/vtec (hybridvteceg)
run the wires from the ecu to the vtec sol., oil pressure, and a knock sensor if you hook it up
Old Mar 9, 2004 | 10:46 PM
tegasaurus's Avatar
Default Re: ls/vtec (redturbocivic)
ok... what ecu pin outs correspond with the vtec solenoid, oil pressure, etc blha?
-ryan
Old Mar 10, 2004 | 06:18 AM
Rod.'s Avatar
https://honda-tech.com/zerothread?id=591747
there you go hope it helps
Old Mar 10, 2004 | 08:24 AM
tegasaurus's Avatar
damn... thanks a ton! that helps out. One last question... where in god's name is the vtec pressure switch?
Old Mar 13, 2004 | 04:18 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">damn... thanks a ton! that helps out. One last question... where in god's name is the vtec pressure switch? </TD></TR></TABLE>
Old Mar 13, 2004 | 07:47 PM
zensoku207's Avatar
Its next to the vtec solenoid in the engine bay?
Old Mar 16, 2004 | 11:24 AM
jdmkid61999's Avatar
haha get a type r oil pump it'll run way better then if you were to use teh ls oil pump and it'll last longer.....the motor i mean
rice a roni
32
Jan 27, 2010 04:15 PM
hondakrazy
Oct 5, 2008 02:16 PM
B18c1turboedEK
Jun 6, 2007 10:07 AM
vtecn8ive
22
Aug 3, 2005 01:06 PM
highcomp
Feb 9, 2004 12:32 AM
