DIY: OEM thin gasket questions
Old Mar 8, 2004 | 03:39 PM
JDMflavor_EJ's Avatar
Default DIY: OEM thin gasket questions
Wassup fellas?
How many here have done the 2-layer OEM gasket trick?
What are your inputs on it?
Anyone have any horror stories? Some people swear by it.
This is for my gsr motor.
Lastly, besides copper is there anyhting better to protect the wear??
Gacias.
Old Mar 8, 2004 | 07:09 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: DIY: OEM thin gasket questions (JDMflavor_EJ)
i've never ever had a problem using 1 or two layers. i always use one and just spray copper on both sides...and yeah i reuse old gaskets.
Old Mar 11, 2004 | 06:32 PM
Default Re: DIY: OEM thin gasket questions (not so civic)
One layer?
Which layer do you choose?
I know with the 2 layer you take the middle one out.
Any other inputs?
Thanks.
Old Mar 12, 2004 | 07:33 AM
i use the top or bottom.
Old May 31, 2004 | 03:32 PM
ORcivicsi's Avatar
damn one layer is risky!
Old May 31, 2004 | 05:23 PM
DonF's Avatar
Default Re: DIY: OEM thin gasket questions (ORcivicsi)
I have done it without problems, but it was a crutch because of time when I could not mill the block, or the pistons were not the cc's I wanted. The 3 layer is superior, but it cost more to disasemble and machine. Always keep a minimum of .035 piston to head with gasket.
1990IntegraLS
Apr 1, 2018 10:32 AM
chasmataz
Jul 25, 2010 08:35 AM
ProPerformance
Jun 16, 2007 08:25 AM
ge_itr
Jan 9, 2007 08:58 PM
pinota
May 28, 2002 09:30 PM
