what mounts is everyone running in your boosted car?
Old Mar 8, 2004 | 02:46 PM
Rob Dizzle's Avatar
Default what mounts is everyone running in your boosted car?
and some direct only opinions might be appreciated.
only direct, first hand experience.
none of this "my buddy has some mounts from that company that starts with a "h" and he thinks they are ****
im curious to know things like if the mounts have held up to over a year of hard driving/racing
does the motor move around more than it did when you first got them in?
things like that.
Old Mar 8, 2004 | 02:52 PM
Kwuaymaikrup's Avatar
Default Re: what mounts is everyone running in your boosted car? (Bob-DC2)
I am running the front and rear energy inserts and my two side mounts I filled with the Window Weld stuff. This bitch is stiff as hell. I don't see it moving anywhere. All in all it cost me around $40 to do all 4. I don't see the point in spending $500 on mounts unless you need custom ones for swaps etc. HTH
-Ryna
Old Mar 8, 2004 | 03:12 PM
boosted-delslow's Avatar
Default Re: what mounts is everyone running in your boosted car? (Kwuaymaikrup)
I am using the energy suspension inserts....they work great but they make everything in the car vibrate. Plus they are only 40 bucks!!! The pepboys by my house actually keeps them in stock. They work great for the money!!!
Old Mar 8, 2004 | 03:13 PM
JdM_y0's Avatar
too much v i b e s
Old Mar 8, 2004 | 03:14 PM
JrCRXHF's Avatar
Default Re: what mounts is everyone running in your boosted car? (boosted-delslow)
hasport
B16 CRX turbo
the motor does not move any more then 1/2 inch
Old Mar 8, 2004 | 03:37 PM
mildly.interesting's Avatar
Place Racing weld-ins...91 SI LS-T
Old Mar 8, 2004 | 04:10 PM
This One's Avatar
Default Re: (mildly interesting)
place racing h22 mounts.... junk
the Passsenger one is broken since the day i got it, the urethane seperated.
So many vibrations and makes the clutch engagement twice as bad with my 6 puck
Old Mar 8, 2004 | 04:14 PM
J.R.'s Avatar
Default Re: (tHIS oNE)
avid
Old Mar 8, 2004 | 04:15 PM
Rob Dizzle's Avatar
Default Re: (J.R.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.R. &raquo;</TD></TR><TR><TD CLASS="quote">avid</TD></TR></TABLE>
how do you like them?
Old Mar 8, 2004 | 04:38 PM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tHIS oNE &raquo;</TD></TR><TR><TD CLASS="quote">place racing h22 mounts.... junk
So many vibrations and makes the clutch engagement twice as bad with my 6 puck</TD></TR></TABLE>
don't they have a lifetime warranty?..
i use the energy suspension inserts, place racing passenger and rear mount, and stock integra driverside.i have a 95 civic, 397 whp/296 trq.
Old Mar 8, 2004 | 05:09 PM
Rod.'s Avatar
Default Re: (espanol)
energy suspension here
Old Mar 8, 2004 | 05:15 PM
AlphaKennyWun's Avatar
Default Re: (redturbocivic)
Hasport rear mount and the rest are stock. Motor barely moves, front suspension feels more solid over bumps, steering wheel shook quite a bit then got better after a month or so.
Old Mar 8, 2004 | 05:19 PM
illi Adik's Avatar
ES Inserts all around. Feels good, I kinda like the vibration.
Old Mar 8, 2004 | 05:20 PM
5thgencivic's Avatar
Default Re: (Jackson4Door)
Windo-welded rear and 2 front lower mounts.
What happened to my rear mount bracket with stock mounts
Modified by 5thgencivic at 5:17 PM 3/8/2004
Old Mar 8, 2004 | 06:04 PM
redboost10's Avatar
Default Re: (5thgencivic)
i have a 99 si, i took the two bottom side mounts off and i got inserts on the two top side mounts, and a place racing motor mount for the back tranny mount.
Old Mar 8, 2004 | 06:11 PM
scttydb411's Avatar
stock mounts with prothane urethane inserts on driver and passenger sides. been too lazy to mount the rear insert. it does vibrate more, but worth it to know i'm not ripping another $90 fluid filled driverside mount.
Old Mar 8, 2004 | 06:19 PM
squirrel's Avatar
ES inserts @ all 5 points ~$30 from ebay
Vibrated a lot at first, but I think everything worked it's way loose now No more rattles
Old Mar 8, 2004 | 07:10 PM
ek9turbo's Avatar
place racing
works great for me , a little vibration when taking off but who cares, i know i dont
Old Mar 8, 2004 | 08:40 PM
XDEep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">I am running the front and rear energy inserts and my two side mounts I filled with the Window Weld stuff. This bitch is stiff as hell. I don't see it moving anywhere. All in all it cost me around $40 to do all 4. I don't see the point in spending $500 on mounts unless you need custom ones for swaps etc. HTH
-Ryna</TD></TR></TABLE>
i did all 4 in windo weld then went to es inserts front/rear and stock sides and theres a lot more vibration than with the windo weld. if i get the chance i will go back to windo weld, except not fill them entirely solid, but leave some gap following the stock design.
Old Mar 8, 2004 | 08:59 PM
This One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by espanol &raquo;</TD></TR><TR><TD CLASS="quote">
yea but that means i have to take the damn thing out and send it to them and wait god knows how long....
in the mean time taking the bus to work.... no thanks
i think i just make a replacement...
Old Mar 8, 2004 | 09:48 PM
Rob Dizzle's Avatar
for the people with inserts, how long have you been running them?
your car doesnt shake too much in the morning when you start her up?
Old Mar 8, 2004 | 09:58 PM
Danger's Avatar
Default Re: (Bob-DC2)
for my integra i went w/ the hasport kit , only cuz they look nice , but im sure that inserts would keep the motor just as stiff . for my Ek hb i chose the place racing driverside solid mount and the ES inserts .
eitherway...solid mounts or inserts will still work the same
Old Mar 8, 2004 | 09:59 PM
ATS*Mark's Avatar
OG triple OG
im running poly inserts on the d series turbo. vibrates a little bit but not that bad.
Old Mar 8, 2004 | 10:12 PM
pissedoffsol's Avatar
25 Year Member
Default Re: (Hella_JDM)
hasports. only mounts any of my cars will see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If you're not getting mounted by Hasport, you're just getting screwed.</TD></TR></TABLE>
Old Mar 8, 2004 | 10:24 PM
XDEep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">for the people with inserts, how long have you been running them?
your car doesnt shake too much in the morning when you start her up?</TD></TR></TABLE>
the only time i notice it is when i turn on the a/c. i need to rev to 1000+ to make it stop vibrating violently.
