auto-manual swap ...please help!!!!
I did a jdm h22 swap with a manual tranny into a 92 Si automatic. I have it running. On the automatic harness where it hooked into the shifter i had to make a jumper for the neutral safety switch so that it would start. Then I couldnt get my keys out cause it thought i was still in drive. So i disconnected the stopper in the ignition switch that holds the key in. Now i do not have reverse lights or cruise control. I know that there are somethings that i am going to have to jump over. I used the auto harness and ran the vtec wires. that all worked fine. Now i just want cruise and reverse lights. Is there another way to wire all this so that i can get cruise and back up lights? Has anyone run into this on a swap and fixed it?
http://www.mazmo.com/zameoj/swap.htm check this link i don't know how much is going to help you but is worth a look
ys1civicsi
12
May 6, 2009 04:55 AM
ekx4
Jul 25, 2005 11:25 AM
