grr detonation is pissin me off
well i got my car tuned back in the day and i still hurd detonation. heres the setup
H23 t3/t4b turbo @8psi
cams
Intake
LIFT -
0.420
DURATION -
258
Exhaust
LIFT -
0.421
DURATION -
258
Hondata s200bd
timing 16 degrees
fuel pressure 39 (idle)
Walburo 255 high pressure
-6AN fuel lines
AEM rail
aeromotive FPR
550 RC injectors
crane ignition
msd coil
shitty *** rev hard pos gay ****** retarted piece of mother bitch manifold that my sister could make better.
3" turbo back
Air fuel
3k rpm- 13.5
4k rpm and up-11.0(playin safe)
so why the hell do i hear mad detonation.... is it the cams?
cams
Intake
LIFT -
0.420
DURATION -
258
Exhaust
LIFT -
0.421
DURATION -
258
Hondata s200bd
timing 16 degrees
-6AN fuel lines
AEM rail
aeromotive FPR
550 RC injectors
crane ignition
msd coil
3" turbo back
Air fuel
3k rpm- 13.5
are you sure its detonation? perhaps another issue?
Put in some high octane and see if the noise goes away. If it doesent, then you have a different problem, if it does, then you need to re-tune it, or make sure your base timing is on.
it sounds like detonation the damn pinging and ****.. its not like loud ping.. but it sounds like theres a bb in my cylinder or someting which detonation sounds like.. what kidna octane level?100?110?
street dreams
Nov 14, 2003 08:30 PM
