Can you use GSR e-brake cables for ITR brakes?
Hey doods,
Im doin a 5 bolt conversion on an EK and I was just wondering if I can use GSR ebrake cables with the rear ITR calipers?
Thanks in advance
Simon
Thanks in advance
Simon
if the GSR and ITR calipers mount in the same location on the hub and the attachment point for the e-brake cable to the caliper is the same then they should fit no problem as they both you use the same attachment method.
cause I'd like to know to since my car has been rotting in my garage for 1yr now. I have 5 lug too on a EJ coupe but don't know what e-brake cable to use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote">if the GSR and ITR calipers mount in the same location on the hub and the attachment point for the e-brake cable to the caliper is the same then they should fit no problem as they both you use the same attachment method.</TD></TR></TABLE>
The ITR rotors are larger, hence the caliper would be out more...
Rikaro
Apr 20, 2007 06:32 AM
Fowler.
18
Sep 28, 2003 08:53 PM
