Can you use GSR e-brake cables for ITR brakes?
Hey doods,
Im doin a 5 bolt conversion on an EK and I was just wondering if I can use GSR ebrake cables with the rear ITR calipers?
Thanks in advance
Simon
Thanks in advance
Simon
at the jetties fishin'
Re: Can you use GSR e-brake cables for ITR brakes? (Redek4)
if the GSR and ITR calipers mount in the same location on the hub and the attachment point for the e-brake cable to the caliper is the same then they should fit no problem as they both you use the same attachment method.
This user can set his title.
Re: Can you use GSR e-brake cables for ITR brakes? (Simon_the_Pieman)
cause I'd like to know to since my car has been rotting in my garage for 1yr now. I have 5 lug too on a EJ coupe but don't know what e-brake cable to use.
Re: Can you use GSR e-brake cables for ITR brakes? (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote">if the GSR and ITR calipers mount in the same location on the hub and the attachment point for the e-brake cable to the caliper is the same then they should fit no problem as they both you use the same attachment method.</TD></TR></TABLE>
The ITR rotors are larger, hence the caliper would be out more...
Rikaro
04-20-2007 06:32 AM
