need help car running to lean
Old Oct 17, 2001 | 06:52 AM
WICKED2's Avatar
New User
Default need help car running to lean
i just got a A/f ratio and its jumping lean to rich, lean to rich don't know what's up and i check my sprk and its white that means i'm running to lean or what?
pls help
Old Oct 17, 2001 | 06:56 AM
rainforest's Avatar
Default Re: need help car running to lean (WICKEDII)
wait a secomd is it doing it really quick like every second. Because it is suppose to do that. If not iam not too sure whats going on can you elebotate.
Old Oct 17, 2001 | 07:12 AM
WICKED2's Avatar
New User
Default Re: need help car running to lean (rainforest)
yes, but how can i check if i'm running lean or rich
Old Oct 17, 2001 | 07:24 AM
rainforest's Avatar
it's the farthest it goes before it goes back that is what you are running. get a fpr and a fuel controler. if you want to really control it.
Old Oct 17, 2001 | 07:29 AM
Austin's Avatar
What you are seeing is normal to the meter that you have...I am assuming that you have an Autometer, or similar guage correct?
Old Oct 17, 2001 | 08:19 AM
WICKED2's Avatar
New User
dis is what i have
93 civic b18C obd1 w/ p72 ecu, FPR
i don't even know if the car is running lean or rich sense the A/F is going crazy
is der anyway dat i check if i'm running to lean or rich
[Modified by WICKEDII, 5:20 PM 10/17/2001]
Old Oct 17, 2001 | 09:51 AM
Austin's Avatar
dis is what i have
Pull the plugs and see what they look like. The guage should show a fairly constant number as you are accelerating at part/full throttle, other than that the ECU is compensating for either a rich or lean condition(any varience from 14.7/1)...the only time that the ECU does not do this is at full throttle where the ECU goes into a closed loop mode and does not read the O2 signal(s).
Austin
Old Oct 17, 2001 | 12:59 PM
DelsolVtec18's Avatar
New User
IT IS NORMAL FOR THE AIR/FUEL GAUGE TO JUMP FROM LEAN TO RICH...LEAN TO RICH...YOUR AIR/FUEL GAUGE IS NOT GOING CRAZY AND YOUR CAR IS RUNNING FINE...IF YOUR SPARK PLUGS ARE WHITE THEN JUST TURN UP YOUR FPR 55PSI WITH THE VACUUM OFF SHOULD BE GOOD.
chrisdean228
May 3, 2017 10:44 AM
MugenT
May 25, 2005 04:58 PM
H22CL
Jun 20, 2004 11:11 AM
jeremy.
Sep 27, 2003 02:12 PM
ludelvr
Sep 28, 2002 09:43 PM
