Tein or Spoon springs - need camber kit?
Well I don't want to put to much $ into the suspension as of right now, because I have another project in the works. However I would like to drop the R a bit seeing how it sits a little high. My ? is with either springs I mentioned above do I need to have a camber kit with them. I would like to stay away from this if possible. THANKS
Also which would you all prefer Spoon or Tein Springs
this is just mho:
kg/mm dr racing springs > tein s-tech > spoon
I like the drop and the rates of the kg/mm best..... (lower + stiffer). No camber ki needed.
-hth
-hth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">this is just mho:
-hth</TD></TR></TABLE>
what exactly are the DR racing springs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegedrex »</TD></TR><TR><TD CLASS="quote">
what exactly are the DR racing springs</TD></TR></TABLE>
KG/MM
I have them and I absolutely love them
the ride with them feels soft but when you corner hard they become stiffer
and the drop is perfect
KG/MM
i have the spoons and i'm currently running skunk2 arms up front and corrected rear camber -- the drop is low enough that i picked up quite a bit of camber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex »</TD></TR><TR><TD CLASS="quote">
KG/MM
and the drop is perfect</TD></TR></TABLE>where did you buy them?
The Spoons, besides sitting a little too low IMO, also were a little too firm for the stock shocks. The stock dampers were just a little overwhelmed by the rates. I'd probably recommend something softer on stock dampers. Also no camber kit needed up front IMO. Rear, just do the washer trick and you'll be find.
If you're going to change out your springs, I'd just got ahead and spend that extra $100-120 or so and put in a adjustible camber kit (Skunk2 or the likes). In the back, like typer 801 said, do the washer trick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux »</TD></TR><TR><TD CLASS="quote">Negative camber is a good thing, embrace it.
So is adjustibility
Adjustible = more possible camber
</TD></TR></TABLE>So is adjustibility
I too have the kg/mm DR progressive lowering springs. I would have to agree with what was said. But like the Spoon progressive springs, The kg/mm, besides sitting a little low, also were a little firm for the stock ITR shocks. The stock dampers seem to be just a little overwhelmed by the rates here on Indiana streets. I would probably go with something softer on stock dampers.
If I want to keep these springs, which shocks should I go with? Koni, KYB AGX, etc?
I also agree with: Also no camber kit needed up front IMO. Rear, just do the washer trick and you'll be fine.
Isn't kg/mm DR the company that makes the Spoon Progressive springs?
