440's or 550's? rc injectors
Old Mar 6, 2004 | 09:57 PM
dunkd's Avatar
Default 440's or 550's? rc injectors
i currently have some rc440's on my car and i want to know if i should upgrade before I head over to have my car tuned, here is my setup...
Stock GSR
t3/60-1 @ 8.7psi, .6bar
holley 255 pump
hondata s200b
jrc 6" fmic
2.5" piping
turbo xs rfl bov
tial 38mm
ssautochrome reworked manifold
skunk2 IM
2.5" downpipe to 2.5" straight exhaust
will RC's be at full load @ this psi? i dont plan on going up on the boost until i build...
Old Mar 6, 2004 | 10:15 PM
TurboJesse
Guest
Posts: n/a
Default Re: 440's or 550's? rc injectors (dunkd)
your 440's should be fine @ that level..
Old Mar 6, 2004 | 11:07 PM
boosted_dc2's Avatar
Default Re: 440's or 550's? rc injectors (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">your 440's should be fine @ that level..</TD></TR></TABLE>
Landon
Old Mar 7, 2004 | 12:39 AM
biassj's Avatar
Default Re: 440's or 550's? rc injectors (boosted_dc2)
Think about how much power you want to make. Go high and lean it out.
Old Mar 7, 2004 | 06:16 AM
FOrSfEd's Avatar
Default Re: 440's or 550's? rc injectors (biassj)
Yeah it depends how much power you want to make. If it's under 300 the 440 should be fine if you want a lil more say 340 or so then 550 would be your best bet.
Old Mar 7, 2004 | 06:39 AM
b16hybridsol's Avatar
bigger is always better
Old Mar 7, 2004 | 07:38 AM
Mad Cow's Avatar
Default Re: (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">bigger is always better</TD></TR></TABLE>
Bigger is not always better. Not only do you waste money if you go too big, it's harder to idle bigger injectors (1000cc, etc). If you plan on upgrading later to make more power, it's pretty easy to scale your fuel map for bigger injectors.
In this case... definatley 550s if you can afford it, and plan to use em.
Modified by MadCow at 11:53 AM 3/7/2004
Old Mar 7, 2004 | 07:43 AM
vtecCJ's Avatar
Get the 550's they should be good for almost 375 whp when tuned right. I have Walbro in-tank pump, with 550's, boosting 15.5 lbs... 2610 lbs car with me in it.
Old Mar 7, 2004 | 08:48 AM
i meant within reason, i wasn't sayin buy 1000cc injectors for a stock motor, common sence, come on
Old Mar 15, 2004 | 11:14 AM
slixxracing's Avatar
550cc are a good investment for future plans if you wanna go for more boost... but as you stated earlier that you didnt wanna do big boost and only want to boost around 7-8 lbs.. 440 should be fine. if the 550cc you said you are going to get are cheap..grab 'em and install them before the dyno..if they arent..save it and invest it towards your block...build up is the best way too boost and the safest way.
JDMmadness
Sep 5, 2011 02:57 PM
B18 rider
Aug 8, 2008 10:51 AM
urnotfast
Mar 20, 2007 06:46 PM
budget
May 8, 2006 08:22 PM
broketuner-Sol_Si
Jan 20, 2006 12:16 PM
