walbro fuel pump for turbo crx at 5 psi
Old Mar 6, 2004 | 06:16 PM
djnikko's Avatar
Default walbro fuel pump for turbo crx at 5 psi
i have SAFC controlling 450cc dsm injectors and a t25 turbo running at 5 psi, should i go with the walbro 255lph fuel pump for extra reliability/tuning
thanks in advance
Old Mar 6, 2004 | 06:55 PM
InTeGrA B18b1's Avatar
Default Re: walbro fuel pump for turbo crx at 5 psi (djnikko)
to be safe you could get it but its not needed.
Old Mar 6, 2004 | 07:26 PM
MikeMAN's Avatar
Default Re: walbro fuel pump for turbo crx at 5 psi (InTeGrA B18b1)
exactly what he said, it wouldn't be bad for insurance but it isn't needed provided your stock pump is in good condition.
mike
Old Mar 6, 2004 | 07:38 PM
xsi-t's Avatar
i say better safe (or safer lol) than sorry
Old Mar 7, 2004 | 02:15 AM
djnikko's Avatar
Default Re: (xsi-t)
exactly my thinking, do i still keep the fuel psi at 40 when the walbro pump is in?
Old Mar 7, 2004 | 05:58 AM
DaX's Avatar
DaX
Loved
Community Favorite
Yeah, at $80, it's cheap insurance. And yes, keep your pressure close to stock.
Old Mar 7, 2004 | 09:47 AM
Joseph Davis's Avatar
Default Re: (DaX)
Stock fuel pump flows enough for 300 whp. I've been beating my HF pump at 5-9 psi for a couple years now. Just to be on the safe side, get one of those Aeromotive fuel pumps and redo your entire fuel system in -8 AN line, with a -6 AN return.
</sarcasm>
Keep the pump stock, and the safest thing you can do with the AFC hack is run the max capacity of your MAP sensor: dial the dizzy back 3 degrees and run 8-10 psi. Don't bother with an MSD BTM as it does nothing to address the way your ignition timing is recurved by the AFC's manipulation of MAP sensor voltage. You'll get ten times the engine life out of running more boost with the AFC hack, than running a fuel pump you don't need.
supabang
Mar 2, 2010 05:54 AM
ridnmyhonda
Apr 1, 2003 01:00 AM
gtcali
Jan 31, 2003 10:01 PM
1tyme
Oct 22, 2002 12:36 PM
DJ0820
Aug 1, 2002 11:56 AM
