can't rev pass 6500....
Old Mar 6, 2004 | 04:52 PM
93vtec's Avatar
Default can't rev pass 6500....
my check engine jusst came on... code is for oxygen sensor heater... will this cause my car not to rev pass 6500???..
Old Mar 6, 2004 | 04:56 PM
madcatz's Avatar
your car i think is in "safe mode"
i think a O2 sensor will cause this too
Old Mar 6, 2004 | 04:57 PM
99spanishGT
Guest
Posts: n/a
Default Re: can't rev pass 6500.... (93vtec)
i have same code but it revs to vtec and past 6500, SO ID SAY NO! sorry about caps
Old Mar 6, 2004 | 05:02 PM
SKDRCR's Avatar
Default Re: (madcatz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcatz &raquo;</TD></TR><TR><TD CLASS="quote">your car i think is in "safe mode"
i think a O2 sensor will cause this too</TD></TR></TABLE>
yep, sounds like his car is in limp dilsnik mode
Old Mar 6, 2004 | 08:38 PM
99spanishGT
Guest
Posts: n/a
Default Re: (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
yep, sounds like his car is in limp dilsnik mode </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spanishlude &raquo;</TD></TR><TR><TD CLASS="quote">i have same code but it revs to vtec and past 6500, SO ID SAY NO! sorry about caps </TD></TR></TABLE>
Old Mar 6, 2004 | 08:41 PM
93vtec's Avatar
i know if the CEL was for the actual o2 sensor then i could still rev pass 6500.. but it's for the o2 sensor heater.. not the o2 sensor... vtec still engages but fuel cuts off at 6500
Old Mar 6, 2004 | 09:08 PM
99spanishGT
Guest
Posts: n/a
Default Re: (93vtec)
code 41 right?? thats what i have and i go to 7500k
Old Mar 7, 2004 | 12:14 AM
93vtec's Avatar
yup.. code 41
Old Mar 15, 2004 | 07:35 PM
DOHCH22ACCORD's Avatar
HEY TRY THIS TAKE THE V TEC PRESSURE SWITCH OFF CLEAN IT WITH SOME BRAKE CLEANER PUT IT BACK ON AND SEE WHAT HAPPENS IF IT WORK U NEED TO CHECK TIMING AND OR BUY NEW SWITCH AND IF SO THE CODE IS 22
G2_Fella
24
Aug 4, 2008 10:51 PM
vxtirent08
Apr 2, 2008 09:13 AM
S4gazm
12
Mar 13, 2007 07:36 PM
Casual Gcode1
Nov 14, 2006 09:33 PM
stehigs321
Jan 5, 2004 12:28 AM
