Antenna making a weird noise (vid)
Old Mar 6, 2004 | 04:36 PM
gsr-2nr's Avatar
Default antenna making weird noise (vid clip) HELP
Maybe I can get further info from you ITR guys regarding this matter since it involves a Integra.
Please follow the link and click the vid:
https://honda-tech.com/zerothread?id=789459
Old Mar 6, 2004 | 05:40 PM
ITR#JohnBasedow's Avatar
Default Re: antenna making weird noise (vid clip) HELP (gsr-2nr)
I had the same problem, so I took off all the panels in the back and disconnected the antenna.
well, unless you listen to the radio a lot.
Old Mar 6, 2004 | 06:52 PM
acurciv's Avatar
Default Re: antenna making weird noise (ITR#jason)
good call, i hate the radio!
Old Mar 6, 2004 | 11:19 PM
gsr-2nr's Avatar
Default Re: antenna making weird noise (acurciv)
unfortunatley that is mostly what i listen to. Does anybody have any suggestions as to what that sound it?
Old Mar 7, 2004 | 04:53 PM
KOALA YUMMIES's Avatar
Default Re: antenna making weird noise (gsr-2nr)
Hahaha that was a funny *** sound. Sounds like it jammed . I think you should pull the antenna, (its pretty damn easy) and experiment with the extending and retracting with it out of the car.
Old Mar 7, 2004 | 08:54 PM
gsr-2nr's Avatar
Default Re: antenna making weird noise (KOALA YUMMIES)
what would b jammed the antenna goes all the way up though thats y im lost as to what the hell this is
Old Mar 7, 2004 | 10:06 PM
nightrider's Avatar
just try to go to a junk yard. it wouldn't be too expensive and you can have your problem solved.
Old Mar 7, 2004 | 10:34 PM
CDN Yellow ITR's Avatar
The cord that pulls the antenna up n down might be broken inside the antenna, happen to me in the summer soo i just disconnected it. tha R looks ugly with the damn antenna up all the time while driving.
Old Mar 7, 2004 | 10:39 PM
B2FiNiTY's Avatar
Default Re: (CDN Yellow ITR)
I suggest taking off the rear panel and have a better look at it.
Old Mar 8, 2004 | 12:46 AM
JDMluvR's Avatar
You can always get an S2k antenna.
Old Mar 8, 2004 | 03:49 PM
gsr-2nr's Avatar
Default Re: antenna making weird noise (JDMluvR)
ehh i said screw it and unplugged the antenna motor, reception isnt to bad just a little static but i can live with that. if it gets real bad ill just use my cd player all the time just so i dont have to get a new motor assembly.
Old Mar 8, 2004 | 04:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">ehh i said screw it and unplugged the antenna motor, reception isnt to bad just a little static but i can live with that. if it gets real bad ill just use my cd player all the time just so i dont have to get a new motor assembly.</TD></TR></TABLE>
Just stick in a CD and use the shuffle mode....to kinda keep things suprising? lol
HondaVerno
Mar 19, 2008 02:57 PM
Kamikaze
Jun 1, 2006 11:46 AM
jonzel
Mar 13, 2006 02:08 PM
gsr-2nr
Mar 15, 2004 08:40 PM
rody084
Mar 13, 2003 06:55 AM
