Airbag screw is stripped. How do i get it off???
Old Mar 6, 2004 | 01:40 PM
phiberoptik's Avatar
Default Airbag screw is stripped. How do i get it off???
SO Im trying to take my stock steering wheel off to put my new wheel on and one of the two airbag screws is stripped. Its a t30 star head but its stripped clean. How the hell can I get this thing out of here?
Old Mar 6, 2004 | 01:50 PM
speedymon's Avatar
Default Re: Airbag screw is stripped. How do i get it off??? (phiberoptik)
I don't know what those bolts look like (flywheel type?), but if worse comes to worse get a dremmel and cut it off.
Old Mar 6, 2004 | 03:49 PM
Kendall's Avatar
Or you can use the dremel to cut a slot in the top of the screw, and use a flat head screwdriver to get it off.
Old Mar 6, 2004 | 05:54 PM
Sobe_Death's Avatar
thats a torx fastener for all you guys who may not know, but you might try an ez-out or one of those new craftsman screw out tools
Old Mar 6, 2004 | 06:47 PM
vtekstorm's Avatar
Default Re: (Sobe_Death)
did u try using needlenose vicegrips that might work better than a dremel
Old Mar 6, 2004 | 07:30 PM
Kendall's Avatar
Default Re: (vtekstorm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekstorm &raquo;</TD></TR><TR><TD CLASS="quote">did u try using needlenose vicegrips that might work better than a dremel </TD></TR></TABLE>
It's not a very good idea. Before I got my dremel I used this method and effectively destroyed several screws that I ended up having to cut off and drill out.
WaryDriver
Sep 25, 2015 04:32 PM
SoFresh1189
17
Feb 19, 2010 10:50 PM
TeamRiskEG6
Oct 16, 2007 08:44 PM
EM2MoNsTeR
17
Nov 30, 2004 02:46 PM
SIR Spooner
Mar 8, 2004 07:50 PM
