skunk 2 IM on b16 head?
Old Mar 6, 2004 | 12:24 PM
roadawg's Avatar
Default skunk 2 IM on b16 head?
I was told I need a type R fuel rail or an aftermarket fuel rail to install my skunk 2 intake manifold on my b16 head.
Is this correct?
Old Mar 6, 2004 | 12:47 PM
King Tut33's Avatar
Default Re: skunk 2 IM on b16 head? (hybrid honda)
No. I have one on my B16a2 head with B16a2 fuel rail. I did have to make custom injector seals for where the fuel injectors seal with the Skunk2 manifold because the B16a2 ones were not tall enough.
Old Mar 6, 2004 | 12:52 PM
roadawg's Avatar
Default Re: skunk 2 IM on b16 head? (King Tut33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">No. I have one on my B16a2 head with B16a2 fuel rail. I did have to make custom injector seals for where the fuel injectors seal with the Skunk2 manifold because the B16a2 ones were not tall enough.</TD></TR></TABLE>
Maybe it is different with a first gen b16 because that is what I have.
Old Mar 6, 2004 | 01:00 PM
King Tut33's Avatar
The intake manifold has nothing to do with the fuel rail other than three studs that you stick in it to hold the fuel rail to the manifold. You swap those off of your old manifold.
Old Mar 6, 2004 | 11:01 PM
zCivic's Avatar
Fuel rails do make a difference on 1st and 2nd gen B16's. The bolt up correctly, but on 1st gens the FPR will hit the IAT on the #2 Runner. You can either get a different fuel rail or relocate you IAT to your intake piping and plug the hole where it would have went in the mani.
Old Mar 7, 2004 | 10:45 AM
gringo7718's Avatar
Default Re: skunk 2 IM on b16 head? (zCivic)
you can use any 94+ integra rail or 2nd gen b16 rail
Old Mar 7, 2004 | 02:11 PM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">Fuel rails do make a difference on 1st and 2nd gen B16's. The bolt up correctly, but on 1st gens the FPR will hit the IAT on the #2 Runner. You can either get a different fuel rail or relocate you IAT to your intake piping and plug the hole where it would have went in the mani. </TD></TR></TABLE>
Thanks
Old Mar 8, 2004 | 05:55 AM
99 TYPE R's Avatar
I swapped everything off of my stock a2 manifold and i works fine
Old Mar 13, 2004 | 06:45 AM
roadawg's Avatar
What is the best way to relocate my IAT to my intake piping?
Do I just plug up the hole where the IAT originally was?
Old Mar 13, 2004 | 12:47 PM
zCivic's Avatar
yeah just plug the center hole fro the IAT sensor. I would tap it and put a plug with some loctite on it. I just drilled and used my orginal IAT sensor held in place with some zipties (ghetto) but works. If you can find a 96-00 civic there also in the intake tube so you may able to use those also
2kdrift
Jan 27, 2014 08:07 AM
mRdUnklOw83
Apr 29, 2012 09:27 PM
Streetreaper
Oct 18, 2007 12:08 PM
Jago
May 28, 2007 07:35 PM
zCivic
Feb 22, 2004 06:23 PM
